Hi, I am using a round column mill/drill and Tormach's TTS. I would love to incorporate a power drawbar that uses the bellville springs to power it instead of of an impact wrench.
What I don't know if it is even possible since it uses a quill which might move under the pressure, other than that I can make just about anything. I have never seen this done (only impact style) on a mill/drill, and I have googled it, looked through tons of threads and found nothing.
Does anyone know if it is possible. The only reason I don't want to use an impact is I foresee it undoing the tormach collet completely causing it to drop out with my tool and I don't want that. So unless someone has figured out a way to keep the drawbar from coming out all the way I think I would not like that method.
