586,075 active members*
3,865 visitors online*
IndustryArena Forum > CAM Software > Vectric > Faster rapids after cutting multiple straight tool paths
Results 1 to 7 of 7
    Oct 2006
    205
    We are cutting 100 straight tools paths that are 24" long in plexiglass. The material is .500 and I am routing down to .400 with a 1.00 dia 90 degree v bit. Cutting speed is 80 ipm.
    Without creating 2 tool paths in each direction, Aspire will not allow cutting in both directions. I'm ok with this.
    However, I would like a faster rapid when returning to beginning of each cut. I believe that it rapids back at the same 80 ipm cutting speeds.
    What controls the rapid speed when not cutting?
    Thanks in advance,
    Rod
    If they are G0 moves, then the machine control would control the speed. If they are G1 moves, then Aspire would. Can you post the g-code?
    Oct 2006
    205
    Gerry,
    I can post the gcode later today.
    Thanks in advance for your help.
    Rod
    Oct 2006
    205
    HI Gerry,
    First of all, thank you in advance for your assistance.
    Here is the small segment of the tool path I mentioned.
    Any help to explain how I can manage the rapids would be appreciated.
    Rod
    ( v 360 horizontal )
    ( File created: Monday, November 19, 2012 - 07:54 PM)
    ( for Mach2/3 from Vectric )
    ( Material Size)
    ( X= 21.000, Y= 18.000, Z= 0.460)
    (Toolpaths used in this file
    (v 360 horizontal)
    (Tools used in this file: )
    (0 = V-Bit {90 deg 1 inches})
    N100G00G20G17G90G40G49G80
    N110G70G91.1
    N120T0M06
    N130 (V-Bit {90 deg 1 inches})
    N140G00G43Z0.8000H0
    N150S100M03
    N160(Toolpath:- v 360 horizontal)
    N170()
    N180G94
    N190X0.0000Y0.0000F189.0
    N200G00X20.5406Y17.3526Z0.5000
    N210G1Z-0.0360F118.1
    N220G1X2.5406F189.0
    N230G00Z0.5000
    N240G00X20.5406
    N250G1Z-0.0720F118.1
    N260G1X2.5406F189.0
    N270G00Z0.5000
    N280G00X20.5406
    N290G1Z-0.1080F118.1
    N300G1X2.5406F189.0
    N310G00Z0.5000
    N320G00X20.5406
    N330G1Z-0.1440F118.1
    N340G1X2.5406F189.0
    N350G00Z0.5000
    N360G00X20.5406
    N370G1Z-0.1800F118.1
    N380G1X2.5406F189.0
    N390G00Z0.5000
    N400G00X20.5406
    N410G1Z-0.2160F118.1
    N420G1X2.5406F189.0
    N430G00Z0.5000
    N440G00X20.5406
    N450G1Z-0.2520F118.1
    N460G1X2.5406F189.0
    N470G00Z0.5000
    N480G00X20.5406
    N490G1Z-0.2880F118.1
    N500G1X2.5406F189.0
    N510G00Z0.5000
    N520G00X20.5406
    N530G1Z-0.3240F118.1
    N540G1X2.5406F189.0
    N550G00Z0.5000
    N560G00X20.5406
    N570G1Z-0.3600F118.1
    N580G1X2.5406F189.0
    N590G00Z0.5000
    N600G00X20.5406Y16.3426
    N610G1Z-0.0360F118.1
    N620G1X2.5406F189.0
    N630G00Z0.5000
    N640G00X20.5406
    N650G1Z-0.0720F118.1
    N660G1X2.5406F189.0
    N670G00Z0.5000
    N680G00X20.5406
    N690G1Z-0.1080F118.1
    N700G1X2.5406F189.0
    N710G00Z0.5000
    N720G00X20.5406
    N730G1Z-0.1440F118.1
    N740G1X2.5406F189.0
    N750G00Z0.5000
    N760G00X20.5406
    N770G1Z-0.1800F118.1
    N780G1X2.5406F189.0
    N790G00Z0.5000
    N800G00X20.5406
    N810G1Z-0.2160F118.1
    N820G1X2.5406F189.0
    N830G00Z0.5000
    N840G00X20.5406
    N850G1Z-0.2520F118.1
    N860G1X2.5406F189.0
    N870G00Z0.5000
    N880G00X20.5406
    N890G1Z-0.2880F118.1
    N900G1X2.5406F189.0
    N910G00Z0.5000
    N920G00X20.5406
    N930G1Z-0.3240F118.1
    N940G1X2.5406F189.0
    N950G00Z0.5000
    N960G00X20.5406
    N970G1Z-0.3600F118.1
    N980G1X2.5406F189.0
    N990G00Z0.5000
    N1000G00X20.5406Y16.0926
    N1010G1Z-0.0360F118.1
    N1020G1X2.5406F189.0
    N1030G00Z0.5000
    N1040G00X20.5406
    N1050G1Z-0.0720F118.1
    N1060G1X2.5406F189.0
    N1070G00Z0.5000
    N1080G00X20.5406
    N1090G1Z-0.1080F118.1
    N1100G1X2.5406F189.0
    N1110G00Z0.5000
    N1120G00X20.5406
    N1130G1Z-0.1440F118.1
    N1140G1X2.5406F189.0
    N1150G00Z0.5000
    N1160G00X20.5406
    N1170G1Z-0.1800F118.1
    N1180G1X2.5406F189.0
    N1190G00Z0.5000
    N1200G00X20.5406
    N1210G1Z-0.2160F118.1
    N1220G1X2.5406F189.0
    N1230G00Z0.5000
    N1240G00X20.5406
    N1250G1Z-0.2520F118.1
    N1260G1X2.5406F189.0
    N1270G00Z0.5000
    N1280G00X20.5406
    N1290G1Z-0.2880F118.1
    N1300G1X2.5406F189.0
    N1310G00Z0.5000
    N1320G00X20.5406
    N1330G1Z-0.3240F118.1
    N1340G1X2.5406F189.0
    N1350G00Z0.5000
    N1360G00X20.5406
    N1370G1Z-0.3600F118.1
    N1380G1X2.5406F189.0
    N1390G00Z0.5000
    N1400G00X20.5406Y15.0826
    N1410G1Z-0.0360F118.1
    N1420G1X2.5406F189.0
    N1430G00Z0.5000
    N1440G00X20.5406
    N1450G1Z-0.0720F118.1
    N1460G1X2.5406F189.0
    N1470G00Z0.5000
    N1480G00X20.5406
    N1490G1Z-0.1080F118.1
    N1500G1X2.5406F189.0
    N1510G00Z0.5000
    N1520G00X20.5406
    N1530G1Z-0.1440F118.1
    N1540G1X2.5406F189.0
    N1550G00Z0.5000
    N1560G00X20.5406
    N1570G1Z-0.1800F118.1
    N1580G1X2.5406F189.0
    N1590G00Z0.5000
    N1600G00X20.5406
    N1610G1Z-0.2160F118.1
    N1620G1X2.5406F189.0
    N1630G00Z0.5000
    N1640G00X20.5406
    N1650G1Z-0.2520F118.1
    N1660G1X2.5406F189.0
    N1670G00Z0.5000
    N1680G00X20.5406
    N1690G1Z-0.2880F118.1
    N1700G1X2.5406F189.0
    N1710G00Z0.5000
    N1720G00X20.5406
    N1730G1Z-0.3240F118.1
    N1740G1X2.5406F189.0
    N1750G00Z0.5000
    N1760G00X20.5406
    N1770G1Z-0.3600F118.1
    N1780G1X2.5406F189.0
    N1790G00Z0.5000
    N1800G00X20.5406Y14.8326
    N1810G1Z-0.0360F118.1
    N1820G1X2.5406F189.0
    N1830G00Z0.5000
    N1840G00X20.5406
    N1850G1Z-0.0720F118.1
    N1860G1X2.5406F189.0
    N1870G00Z0.5000
    N1880G00X20.5406
    N1890G1Z-0.1080F118.1
    N1900G1X2.5406F189.0
    N1910G00Z0.5000
    N1920G00X20.5406
    N1930G1Z-0.1440F118.1
    N1940G1X2.5406F189.0
    N1950G00Z0.5000
    N1960G00X20.5406
    N1970G1Z-0.1800F118.1
    N1980G1X2.5406F189.0
    N1990G00Z0.5000
    N2000G00X20.5406
    N2010G1Z-0.2160F118.1
    N2020G1X2.5406F189.0
    N2030G00Z0.5000
    N2040G00X20.5406
    N2050G1Z-0.2520F118.1
    N2060G1X2.5406F189.0
    N2070G00Z0.5000
    N2080G00X20.5406
    N2090G1Z-0.2880F118.1
    N2100G1X2.5406F189.0
    N2110G00Z0.5000
    N2120G00X20.5406
    N2130G1Z-0.3240F118.1
    N2140G1X2.5406F189.0
    N2150G00Z0.5000
    N2160G00X20.5406
    N2170G1Z-0.3600F118.1
    N2180G1X2.5406F189.0
    N2190G00Z0.5000
    N2200G00X20.5406Y13.8226
    N2210G1Z-0.0360F118.1
    N2220G1X2.5406F189.0
    N2230G00Z0.5000
    N2240G00X20.5406
    N2250G1Z-0.0720F118.1
    N2260G1X2.5406F189.0
    N2270G00Z0.5000
    N2280G00X20.5406
    N2290G1Z-0.1080F118.1
    N2300G1X2.5406F189.0
    N2310G00Z0.5000
    N2320G00X20.5406
    N2330G1Z-0.1440F118.1
    N2340G1X2.5406F189.0
    N2350G00Z0.5000
    N2360G00X20.5406
    N2370G1Z-0.1800F118.1
    N2380G1X2.5406F189.0
    N2390G00Z0.5000
    N2400G00X20.5406
    N2410G1Z-0.2160F118.1
    N2420G1X2.5406F189.0
    N2430G00Z0.5000
    N2440G00X20.5406
    N2450G1Z-0.2520F118.1
    N2460G1X2.5406F189.0
    N2470G00Z0.5000
    N2480G00X20.5406
    N2490G1Z-0.2880F118.1
    N2500G1X2.5406F189.0
    N2510G00Z0.5000
    N2520G00X20.5406
    N2530G1Z-0.3240F118.1
    N2540G1X2.5406F189.0
    N2550G00Z0.5000
    N2560G00X20.5406
    N2570G1Z-0.3600F118.1
    N2580G1X2.5406F189.0
    N2590G00Z0.5000
    N2600G00X20.5406Y13.5726
    N2610G1Z-0.0360F118.1
    N2620G1X2.5406F189.0
    N2630G00Z0.5000
    N2640G00X20.5406
    N2650G1Z-0.0720F118.1
    N2660G1X2.5406F189.0
    N2670G00Z0.5000
    N2680G00X20.5406
    N2690G1Z-0.1080F118.1
    N2700G1X2.5406F189.0
    N2710G00Z0.5000
    N2720G00X20.5406
    N2730G1Z-0.1440F118.1
    N2740G1X2.5406F189.0
    N2750G00Z0.5000
    N2760G00X20.5406
    N2770G1Z-0.1800F118.1
    N2780G1X2.5406F189.0
    N2790G00Z0.5000
    N2800G00X20.5406
    N2810G1Z-0.2160F118.1
    N2820G1X2.5406F189.0
    N2830G00Z0.5000
    N2840G00X20.5406
    N2850G1Z-0.2520F118.1
    N2860G1X2.5406F189.0
    N2870G00Z0.5000
    N2880G00X20.5406
    N2890G1Z-0.2880F118.1
    N2900G1X2.5406F189.0
    N2910G00Z0.5000
    N2920G00X20.5406
    N2930G1Z-0.3240F118.1
    N2940G1X2.5406F189.0
    N2950G00Z0.5000
    N2960G00X20.5406
    N2970G1Z-0.3600F118.1
    N2980G1X2.5406F189.0
    N2990G00Z0.5000
    N3000G00X20.5406Y12.5626
    N3010G1Z-0.0360F118.1
    N3020G1X2.5406F189.0
    N3030G00Z0.5000
    N3040G00X20.5406
    N3050G1Z-0.0720F118.1
    N3060G1X2.5406F189.0
    N3070G00Z0.5000
    N3080G00X20.5406
    N3090G1Z-0.1080F118.1
    N3100G1X2.5406F189.0
    N3110G00Z0.5000
    N3120G00X20.5406
    N3130G1Z-0.1440F118.1
    N3140G1X2.5406F189.0
    N3150G00Z0.5000
    N3160G00X20.5406
    N3170G1Z-0.1800F118.1
    N3180G1X2.5406F189.0
    N3190G00Z0.5000
    N3200G00X20.5406
    N3210G1Z-0.2160F118.1
    N3220G1X2.5406F189.0
    N3230G00Z0.5000
    N3240G00X20.5406
    N3250G1Z-0.2520F118.1
    N3260G1X2.5406F189.0
    N3270G00Z0.5000
    N3280G00X20.5406
    N3290G1Z-0.2880F118.1
    N3300G1X2.5406F189.0
    N3310G00Z0.5000
    N3320G00X20.5406
    N3330G1Z-0.3240F118.1
    N3340G1X2.5406F189.0
    N3350G00Z0.5000
    N3360G00X20.5406
    N3370G1Z-0.3600F118.1
    N3380G1X2.5406F189.0
    N3390G00Z0.5000
    N3400G00X20.5406Y12.3126
    N3410G1Z-0.0360F118.1
    N3420G1X2.5406F189.0
    N3430G00Z0.5000
    N3440G00X20.5406
    N3450G1Z-0.0720F118.1
    N3460G1X2.5406F189.0
    N3470G00Z0.5000
    N3480G00X20.5406
    N3490G1Z-0.1080F118.1
    N3500G1X2.5406F189.0
    N3510G00Z0.5000
    N3520G00X20.5406
    N3530G1Z-0.1440F118.1
    N3540G1X2.5406F189.0
    N3550G00Z0.5000
    N3560G00X20.5406
    N3570G1Z-0.1800F118.1
    N3580G1X2.5406F189.0
    N3590G00Z0.5000
    N3600G00X20.5406
    N3610G1Z-0.2160F118.1
    N3620G1X2.5406F189.0
    N3630G00Z0.5000
    N3640G00X20.5406
    N3650G1Z-0.2520F118.1
    N3660G1X2.5406F189.0
    N3670G00Z0.5000
    N3680G00X20.5406
    N3690G1Z-0.2880F118.1
    N3700G1X2.5406F189.0
    N3710G00Z0.5000
    N3720G00X20.5406
    N3730G1Z-0.3240F118.1
    N3740G1X2.5406F189.0
    N3750G00Z0.5000
    N3760G00X20.5406
    N3770G1Z-0.3600F118.1
    N3780G1X2.5406F189.0
    N3790G00Z0.5000
    N3800G00X20.5406Y11.3026
    N3810G1Z-0.0360F118.1
    N3820G1X2.5406F189.0
    N3830G00Z0.5000
    N3840G00X20.5406
    N3850G1Z-0.0720F118.1
    N3860G1X2.5406F189.0
    N3870G00Z0.5000
    N3880G00X20.5406
    N3890G1Z-0.1080F118.1
    N3900G1X2.5406F189.0
    N3910G00Z0.5000
    N3920G00X20.5406
    N3930G1Z-0.1440F118.1
    N3940G1X2.5406F189.0
    N3950G00Z0.5000
    N3960G00X20.5406
    N3970G1Z-0.1800F118.1
    N3980G1X2.5406F189.0
    N3990G00Z0.5000
    N4000G00X20.5406
    N4010G1Z-0.2160F118.1
    N4020G1X2.5406F189.0
    N4030G00Z0.5000
    N4040G00X20.5406
    N4050G1Z-0.2520F118.1
    N4060G1X2.5406F189.0
    N4070G00Z0.5000
    N4080G00X20.5406
    N4090G1Z-0.2880F118.1
    N4100G1X2.5406F189.0
    N4110G00Z0.5000
    N4120G00X20.5406
    N4130G1Z-0.3240F118.1
    N4140G1X2.5406F189.0
    N4150G00Z0.5000
    N4160G00X20.5406
    N4170G1Z-0.3600F118.1
    N4180G1X2.5406F189.0
    N4190G00Z0.5000
    N4200G00X20.5406Y11.0526
    N4210G1Z-0.0360F118.1
    N4220G1X2.5406F189.0
    N4230G00Z0.5000
    N4240G00X20.5406
    N4250G1Z-0.0720F118.1
    N4260G1X2.5406F189.0
    N4270G00Z0.5000
    N4280G00X20.5406
    N4290G1Z-0.1080F118.1
    N4300G1X2.5406F189.0
    N4310G00Z0.5000
    N4320G00X20.5406
    N4330G1Z-0.1440F118.1
    N4340G1X2.5406F189.0
    N4350G00Z0.5000
    N4360G00X20.5406
    N4370G1Z-0.1800F118.1
    N4380G1X2.5406F189.0
    N4390G00Z0.5000
    N4400G00X20.5406
    N4410G1Z-0.2160F118.1
    N4420G1X2.5406F189.0
    N4430G00Z0.5000
    N4440G00X20.5406
    N4450G1Z-0.2520F118.1
    N4460G1X2.5406F189.0
    N4470G00Z0.5000
    N4480G00X20.5406
    N4490G1Z-0.2880F118.1
    N4500G1X2.5406F189.0
    N4510G00Z0.5000
    N4520G00X20.5406
    N4530G1Z-0.3240F118.1
    N4540G1X2.5406F189.0
    N4550G00Z0.5000
    N4560G00X20.5406
    N4570G1Z-0.3600F118.1
    N4580G1X2.5406F189.0
    N4590G00Z0.5000
    N4600G00X20.5406Y10.0426
    N4610G1Z-0.0360F118.1
    N4620G1X2.5406F189.0
    N4630G00Z0.5000
    N4640G00X20.5406
    N4650G1Z-0.0720F118.1
    N4660G1X2.5406F189.0
    N4670G00Z0.5000
    N4680G00X20.5406
    N4690G1Z-0.1080F118.1
    N4700G1X2.5406F189.0
    N4710G00Z0.5000
    N4720G00X20.5406
    N4730G1Z-0.1440F118.1
    N4740G1X2.5406F189.0
    N4750G00Z0.5000
    N4760G00X20.5406
    N4770G1Z-0.1800F118.1
    N4780G1X2.5406F189.0
    N4790G00Z0.5000
    N4800G00X20.5406
    N4810G1Z-0.2160F118.1
    N4820G1X2.5406F189.0
    N4830G00Z0.5000
    N4840G00X20.5406
    N4850G1Z-0.2520F118.1
    N4860G1X2.5406F189.0
    N4870G00Z0.5000
    N4880G00X20.5406
    N4890G1Z-0.2880F118.1
    N4900G1X2.5406F189.0
    N4910G00Z0.5000
    N4920G00X20.5406
    N4930G1Z-0.3240F118.1
    N4940G1X2.5406F189.0
    N4950G00Z0.5000
    N4960G00X20.5406
    N4970G1Z-0.3600F118.1
    N4980G1X2.5406F189.0
    N4990G00Z0.5000
    N5000G00X20.5073Y9.7926
    N5010G1Z-0.0360F118.1
    N5020G1X2.5073F189.0
    N5030G00Z0.5000
    N5040G00X20.5073
    N5050G1Z-0.0720F118.1
    N5060G1X2.5073F189.0
    N5070G00Z0.5000
    N5080G00X20.5073
    N5090G1Z-0.1080F118.1
    N5100G1X2.5073F189.0
    N5110G00Z0.5000
    N5120G00X20.5073
    N5130G1Z-0.1440F118.1
    N5140G1X2.5073F189.0
    N5150G00Z0.5000
    N5160G00X20.5073
    N5170G1Z-0.1800F118.1
    N5180G1X2.5073F189.0
    N5190G00Z0.5000
    N5200G00X20.5073
    N5210G1Z-0.2160F118.1
    N5220G1X2.5073F189.0
    N5230G00Z0.5000
    N5240G00X20.5073
    N5250G1Z-0.2520F118.1
    N5260G1X2.5073F189.0
    N5270G00Z0.5000
    N5280G00X20.5073
    N5290G1Z-0.2880F118.1
    N5300G1X2.5073F189.0
    N5310G00Z0.5000
    N5320G00X20.5073
    N5330G1Z-0.3240F118.1
    N5340G1X2.5073F189.0
    N5350G00Z0.5000
    N5360G00X20.5073
    N5370G1Z-0.3600F118.1
    N5380G1X2.5073F189.0
    N5390G00Z0.5000
    N5400G00X20.5073Y8.7839
    N5410G1Z-0.0360F118.1
    N5420G1X2.5073F189.0
    N5430G00Z0.5000
    N5440G00X20.5073
    N5450G1Z-0.0720F118.1
    N5460G1X2.5073F189.0
    N5470G00Z0.5000
    N5480G00X20.5073
    N5490G1Z-0.1080F118.1
    N5500G1X2.5073F189.0
    N5510G00Z0.5000
    N5520G00X20.5073
    N5530G1Z-0.1440F118.1
    N5540G1X2.5073F189.0
    N5550G00Z0.5000
    N5560G00X20.5073
    N5570G1Z-0.1800F118.1
    N5580G1X2.5073F189.0
    N5590G00Z0.5000
    N5600G00X20.5073
    N5610G1Z-0.2160F118.1
    N5620G1X2.5073F189.0
    N5630G00Z0.5000
    N5640G00X20.5073
    N5650G1Z-0.2520F118.1
    N5660G1X2.5073F189.0
    N5670G00Z0.5000
    N5680G00X20.5073
    N5690G1Z-0.2880F118.1
    N5700G1X2.5073F189.0
    N5710G00Z0.5000
    N5720G00X20.5073
    N5730G1Z-0.3240F118.1
    N5740G1X2.5073F189.0
    N5750G00Z0.5000
    N5760G00X20.5073
    N5770G1Z-0.3600F118.1
    N5780G1X2.5073F189.0
    N5790G00Z0.5000
    N5800G00X20.5073Y8.5339
    N5810G1Z-0.0360F118.1
    N5820G1X2.5073F189.0
    N5830G00Z0.5000
    N5840G00X20.5073
    N5850G1Z-0.0720F118.1
    N5860G1X2.5073F189.0
    N5870G00Z0.5000
    N5880G00X20.5073
    N5890G1Z-0.1080F118.1
    N5900G1X2.5073F189.0
    N5910G00Z0.5000
    N5920G00X20.5073
    N5930G1Z-0.1440F118.1
    N5940G1X2.5073F189.0
    N5950G00Z0.5000
    N5960G00X20.5073
    N5970G1Z-0.1800F118.1
    N5980G1X2.5073F189.0
    N5990G00Z0.5000
    N6000G00X20.5073
    N6010G1Z-0.2160F118.1
    N6020G1X2.5073F189.0
    N6030G00Z0.5000
    N6040G00X20.5073
    N6050G1Z-0.2520F118.1
    N6060G1X2.5073F189.0
    N6070G00Z0.5000
    N6080G00X20.5073
    N6090G1Z-0.2880F118.1
    N6100G1X2.5073F189.0
    N6110G00Z0.5000
    N6120G00X20.5073
    N6130G1Z-0.3240F118.1
    N6140G1X2.5073F189.0
    N6150G00Z0.5000
    N6160G00X20.5073
    N6170G1Z-0.3600F118.1
    N6180G1X2.5073F189.0
    N6190G00Z0.5000
    N6200G00X20.5156Y7.2763
    N6210G1Z-0.0360F118.1
    N6220G1X2.5156F189.0
    N6230G00Z0.5000
    N6240G00X20.5156
    N6250G1Z-0.0720F118.1
    N6260G1X2.5156F189.0
    N6270G00Z0.5000
    N6280G00X20.5156
    N6290G1Z-0.1080F118.1
    N6300G1X2.5156F189.0
    N6310G00Z0.5000
    N6320G00X20.5156
    N6330G1Z-0.1440F118.1
    N6340G1X2.5156F189.0
    N6350G00Z0.5000
    N6360G00X20.5156
    N6370G1Z-0.1800F118.1
    N6380G1X2.5156F189.0
    N6390G00Z0.5000
    N6400G00X20.5156
    N6410G1Z-0.2160F118.1
    N6420G1X2.5156F189.0
    N6430G00Z0.5000
    N6440G00X20.5156
    N6450G1Z-0.2520F118.1
    N6460G1X2.5156F189.0
    N6470G00Z0.5000
    N6480G00X20.5156
    N6490G1Z-0.2880F118.1
    N6500G1X2.5156F189.0
    N6510G00Z0.5000
    N6520G00X20.5156
    N6530G1Z-0.3240F118.1
    N6540G1X2.5156F189.0
    N6550G00Z0.5000
    N6560G00X20.5156
    N6570G1Z-0.3600F118.1
    N6580G1X2.5156F189.0
    N6590G00Z0.5000
    N6600G00X20.5406Y7.5251
    N6610G1Z-0.0360F118.1
    N6620G1X2.5406F189.0
    N6630G00Z0.5000
    N6640G00X20.5406
    N6650G1Z-0.0720F118.1
    N6660G1X2.5406F189.0
    N6670G00Z0.5000
    N6680G00X20.5406
    N6690G1Z-0.1080F118.1
    N6700G1X2.5406F189.0
    N6710G00Z0.5000
    N6720G00X20.5406
    N6730G1Z-0.1440F118.1
    N6740G1X2.5406F189.0
    N6750G00Z0.5000
    N6760G00X20.5406
    N6770G1Z-0.1800F118.1
    N6780G1X2.5406F189.0
    N6790G00Z0.5000
    N6800G00X20.5406
    N6810G1Z-0.2160F118.1
    N6820G1X2.5406F189.0
    N6830G00Z0.5000
    N6840G00X20.5406
    N6850G1Z-0.2520F118.1
    N6860G1X2.5406F189.0
    N6870G00Z0.5000
    N6880G00X20.5406
    N6890G1Z-0.2880F118.1
    N6900G1X2.5406F189.0
    N6910G00Z0.5000
    N6920G00X20.5406
    N6930G1Z-0.3240F118.1
    N6940G1X2.5406F189.0
    N6950G00Z0.5000
    N6960G00X20.5406
    N6970G1Z-0.3600F118.1
    N6980G1X2.5406F189.0
    N6990G00Z0.5000
    N7000G00X20.5156Y6.2663
    N7010G1Z-0.0360F118.1
    N7020G1X2.5156F189.0
    N7030G00Z0.5000
    N7040G00X20.5156
    N7050G1Z-0.0720F118.1
    N7060G1X2.5156F189.0
    N7070G00Z0.5000
    N7080G00X20.5156
    N7090G1Z-0.1080F118.1
    N7100G1X2.5156F189.0
    N7110G00Z0.5000
    N7120G00X20.5156
    N7130G1Z-0.1440F118.1
    N7140G1X2.5156F189.0
    N7150G00Z0.5000
    N7160G00X20.5156
    N7170G1Z-0.1800F118.1
    N7180G1X2.5156F189.0
    N7190G00Z0.5000
    N7200G00X20.5156
    N7210G1Z-0.2160F118.1
    N7220G1X2.5156F189.0
    N7230G00Z0.5000
    N7240G00X20.5156
    N7250G1Z-0.2520F118.1
    N7260G1X2.5156F189.0
    N7270G00Z0.5000
    N7280G00X20.5156
    N7290G1Z-0.2880F118.1
    N7300G1X2.5156F189.0
    N7310G00Z0.5000
    N7320G00X20.5156
    N7330G1Z-0.3240F118.1
    N7340G1X2.5156F189.0
    N7350G00Z0.5000
    N7360G00X20.5156
    N7370G1Z-0.3600F118.1
    N7380G1X2.5156F189.0
    N7390G00Z0.5000
    N7400G00X20.5156Y6.0163
    N7410G1Z-0.0360F118.1
    N7420G1X2.5156F189.0
    N7430G00Z0.5000
    N7440G00X20.5156
    N7450G1Z-0.0720F118.1
    N7460G1X2.5156F189.0
    N7470G00Z0.5000
    N7480G00X20.5156
    N7490G1Z-0.1080F118.1
    N7500G1X2.5156F189.0
    N7510G00Z0.5000
    N7520G00X20.5156
    N7530G1Z-0.1440F118.1
    N7540G1X2.5156F189.0
    N7550G00Z0.5000
    N7560G00X20.5156
    N7570G1Z-0.1800F118.1
    N7580G1X2.5156F189.0
    N7590G00Z0.5000
    N7600G00X20.5156
    N7610G1Z-0.2160F118.1
    N7620G1X2.5156F189.0
    N7630G00Z0.5000
    N7640G00X20.5156
    N7650G1Z-0.2520F118.1
    N7660G1X2.5156F189.0
    N7670G00Z0.5000
    N7680G00X20.5156
    N7690G1Z-0.2880F118.1
    N7700G1X2.5156F189.0
    N7710G00Z0.5000
    N7720G00X20.5156
    N7730G1Z-0.3240F118.1
    N7740G1X2.5156F189.0
    N7750G00Z0.5000
    N7760G00X20.5156
    N7770G1Z-0.3600F118.1
    N7780G1X2.5156F189.0
    N7790G00Z0.5000
    N7800G00X20.5156Y5.0063
    N7810G1Z-0.0360F118.1
    N7820G1X2.5156F189.0
    N7830G00Z0.5000
    N7840G00X20.5156
    N7850G1Z-0.0720F118.1
    N7860G1X2.5156F189.0
    N7870G00Z0.5000
    N7880G00X20.5156
    N7890G1Z-0.1080F118.1
    N7900G1X2.5156F189.0
    N7910G00Z0.5000
    N7920G00X20.5156
    N7930G1Z-0.1440F118.1
    N7940G1X2.5156F189.0
    N7950G00Z0.5000
    N7960G00X20.5156
    N7970G1Z-0.1800F118.1
    N7980G1X2.5156F189.0
    N7990G00Z0.5000
    N8000G00X20.5156
    N8010G1Z-0.2160F118.1
    N8020G1X2.5156F189.0
    N8030G00Z0.5000
    N8040G00X20.5156
    N8050G1Z-0.2520F118.1
    N8060G1X2.5156F189.0
    N8070G00Z0.5000
    N8080G00X20.5156
    N8090G1Z-0.2880F118.1
    N8100G1X2.5156F189.0
    N8110G00Z0.5000
    N8120G00X20.5156
    N8130G1Z-0.3240F118.1
    N8140G1X2.5156F189.0
    N8150G00Z0.5000
    N8160G00X20.5156
    N8170G1Z-0.3600F118.1
    N8180G1X2.5156F189.0
    N8190G00Z0.5000
    N8200G00X20.5156Y4.7563
    N8210G1Z-0.0360F118.1
    N8220G1X2.5156F189.0
    N8230G00Z0.5000
    N8240G00X20.5156
    N8250G1Z-0.0720F118.1
    N8260G1X2.5156F189.0
    N8270G00Z0.5000
    N8280G00X20.5156
    N8290G1Z-0.1080F118.1
    N8300G1X2.5156F189.0
    N8310G00Z0.5000
    N8320G00X20.5156
    N8330G1Z-0.1440F118.1
    N8340G1X2.5156F189.0
    N8350G00Z0.5000
    N8360G00X20.5156
    N8370G1Z-0.1800F118.1
    N8380G1X2.5156F189.0
    N8390G00Z0.5000
    N8400G00X20.5156
    N8410G1Z-0.2160F118.1
    N8420G1X2.5156F189.0
    N8430G00Z0.5000
    N8440G00X20.5156
    N8450G1Z-0.2520F118.1
    N8460G1X2.5156F189.0
    N8470G00Z0.5000
    N8480G00X20.5156
    N8490G1Z-0.2880F118.1
    N8500G1X2.5156F189.0
    N8510G00Z0.5000
    N8520G00X20.5156
    N8530G1Z-0.3240F118.1
    N8540G1X2.5156F189.0
    N8550G00Z0.5000
    N8560G00X20.5156
    N8570G1Z-0.3600F118.1
    N8580G1X2.5156F189.0
    N8590G00Z0.5000
    N8600G00Z0.8000
    N8610G00X0.0000Y0.0000
    N8620M09
    N8630M30
    Couple things.
    1) Your g-code is programmed to cut at 189ipm, not 80.
    Sounds like your motor tuning is set to 80ipm, which is limiting both your cutting speeds and rapids to 80ipm.
    The Velocity setting in Mach3's motor tuning screens is what the rapid speeds are.
    If you want to minimize the rapid moves, try using a Fluting toolpath. Set it to ramp at both ends, and set the ramp distance to 0.0. It will lift at each end, but then go back down and cut in both directions, with no rapids. Should be a LOT faster.
    Oct 2006
    205
    Gerry,
    You are right about the 189 inches per minute. I was setting it at 80 mm/sec in Aspire and thought I was cutting at 80 inches per minute. Both ipm and mm/ses translates to the same speeds.
    Thanks for the suggestion for the fluting tool path. Now that I made changes to the motor tuning, I can rapid back to the cut start at Velocity of 544 inches per minute. Wow, this is fast and don't need to cut in both directions any more.
    Also, thanks for the suggestion for the motor tuning. I maxed out the accel and velocity for both x and y axis and now have Velocity set at 544 and Accel at 120 inches per minute.
    Wow, what a improvement in speeds! I don't normally cut at these speeds, but it's good to know it's possible. Maybe good for cutting foam or for showing off to friends.
    I can now max out the full potential of the DMM servos I have.
    Thanks again,
    Rod
    Jan 2007
    1795
    you can cut on a zig-zag path down...
    Vectric Forum • View topic - How do I cut back and forth on a single line?
    Vectric Forum • View topic - Profile Toolpath That Rasters in the Zaxis?
    it is a long time issue.. migthbe some day it will be added..
    ace converter from dakeng website as i remember does forth n back toolpathing...
  1. Replies: 12
    Last Post: 05-17-2012, 03:21 AM
  2. Gearing a machine for faster rapids help please
    By Ranscon in forum DIY CNC Router Table Machines
    Last Post: 08-28-2010, 05:50 AM
  3. WHAT PARAMETERS MAKE THE RAPIDS FASTER
    By PROGRAMERDAVE in forum Haas Mills
    Last Post: 10-13-2009, 04:32 AM
  4. Will a solid carbide bit cut faster that a straight cutting bit?
    By Apples in forum DIY CNC Router Table Machines
    Last Post: 09-11-2006, 01:10 PM
