586,104 active members*
3,367 visitors online*
Thread: Vectric 2d
    Oct 2008
    248
    Vectric 2d
    Hi everyone, I tried yesterday to assign tool paths to something I'm working on, and for some reason when it cuts it has a lot of up and down Z axis movement. It's like the engraving has broken/open chains or something. The link is a picture of the engraving, the deer is what giving me trouble.
    Feb 2007
    532
    Hi...
    If not broken chains, do you have duplicate vectors in the deer?
    Before I upgraded to vcarve I had problems with cut2D doing some keyring engraving that turned out to be duplicate vector issues.
    Also, are you pocketing between two lines, or engraving on one?
    Are you happy to post a DXF to check out?
    Cheers, Chris H.
    Oct 2008
    248
    Quote Originally Posted by kiwichris View Post
    Hi...
    Cheers, Chris H.
    Thanks for the reply. I can post a DXF tonight when I Get home from work. The finished engraving in the picture was set up in another program and turned out good, it engraved the deer in one pass no problems. I'm engraving on the line.
    Mike
    Oct 2008
    248
    Hi...
    Cheers, Chris H.
    I figured it out. I joined all the vectors with the edit vectors button, and all is good. Thanks
    Mike
  1. Vectric Forums...
    By kiwichris in forum Vectric
    Last Post: 01-15-2014, 11:30 AM
  2. Which Vectric Products do I need?
    By ntww in forum Vectric
    Last Post: 06-25-2011, 11:25 PM
  3. Help with Mach3, Vectric
    By oldskimmer in forum DIY CNC Router Table Machines
    Last Post: 06-30-2009, 09:53 PM
  4. WTB Vectric
    By tdnp in forum Vectric
    Last Post: 03-22-2009, 04:43 PM
