x43=counter used to count number of failed attempts at something. either number is ok as you should not fail stuff
[Lancer 6000rpm is 30, urs shud be 10]
x45=pos test; counter used to count number of failed attempts at orient. either number is ok as you should not fail stuff
[Lancer 6000rpm is 3, urs shud be 1]
x47=open loop (not orienting) position gain - so dont care here [Arrow 8000rpm is 2000, urs shud be 5000]
x50= ditto but again during orient so dont care here. [Arrow 8000rpm is 2000, urs shud be 5000]
We normally see UV faults in error history - this is NORMALLY not a faut, but as Marer1ck told you it MAY be a fault if it is the CAUSE instead of RESULT of undervolts..... 99% of the time when it is the CAUSE, the problem is defective POWER SUPPLY (PSR4) instead - and usually happens during accel UPTO speed or heavy machining..... so from your symptoms I would put this fault in the SYMPTOM column as M. did.
The other faults you mentioned are cause from only 1 of 2 things:
- YOU typed crap in MOtionLink and cause it NOW
- or the VFS5's battery backed EPROM is dying and needs replaced (we do dailyl).
Hope this helps.
