586,077 active members*
3,712 visitors online*
Results 1 to 3 of 3
    Nov 2012
    Angry DSP Controller issues
    Hi All
    Have hit a snag on my DSP (0105) that I cannot get past. On startup message tells you that Y+ hard limit is out and needs adjusting; how does one fix this or what could be the cause?
    Thank you!
    Do in this way. Turn on DSP of cnc wood router, after HOME OPERATION finished, get into manual mode. Then press HOME, now you come to the screen with a list, such as MACH SETUP, AUTO PRO SET UP, choose SYSTEM SETUP, then choose FUNCTION set, then there is one item about the hardlimit, close this hard limit function. Then no problem. It is because DSP0501 version does not support hardlimit setting.
    Be care about some setting up function in DSP, do not change it often.
    Amanda Cheung from OMNI, www.omni-cnc.com,
    [email protected], Skype: omni-cnc
    Nov 2012
    Good day
    Thank you very much!
  1. 6535 controller issues
    By BuckeyenNJ in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 11-19-2012, 03:17 AM
  2. 6000 series controller & THC issues
    By Mike 1948 in forum DynaCNC
    Last Post: 09-01-2009, 01:02 PM
  3. Controller issues, in the home stretch
    By bp092 in forum Gecko Drives
    Last Post: 03-18-2008, 10:41 PM
  4. PIC 18F Controller Issues
    By Katratszi in forum Open Source Controller Boards
    Last Post: 11-12-2007, 08:00 AM
  5. Controller issues
    By Selmac in forum DNC Problems and Solutions
    Last Post: 09-25-2006, 05:39 PM
