I recently purchased an X2 from Cummins. When I unpacked it, I found the power supply enclosure broken in half a dozen pieces. It looked as though
someone packed it that way, as the crate showed no signs of impact.
Anyway, rather than trying to get a replacement, I decided to just mount
the guts in my own enclosure. I chose an old PC power supply case and it turned out to be better than the original. I only needed to relocate the stand-offs for the circuit board. Everything else just fell into place. I even reused the plastic sheet that insulated the PC power supply board from the case. The fan is roughly 4 times larger too!
