I hooked up my new indexing head and can't get it to go both
Directions ,I'm using Mach2
Works in Mach 3 , but not Mach 2
So why are you using Mach2, then?
Andrew Werby
www.computersculpture.com
I like Mach 2 better for the jog functions are better.
The jog functions are (or should be) the same. What's different for you? Have you found the jog panel that opens when you hit the "tab" key?
Andrew Werby
Thanks a lot, forgot about the Tab key,
It has been a long time since I used Mach III
This is much better now.
