587,048 active members*
2,554 visitors online*
    Nov 2011
    15
    Looking for a BT30 Spindle
    Does anyone know of a good supplier for BT30 spindles? 1-3 HP and approx 3000RPM. I would love to find a cartridge design w/ a build in mechanism for pull stud retention. I plan to belt drive it from the spindle motor.
    I've come across a nice little unit from a Brother TC211, but it's probably not meant for milling (drill tap machine). It has small 62mm bearings.
    Any help would be greatly appreciated.
    Thanks!
    Feb 2009
    6028
    All 30 taper spindles will have rather small bearings. The brothers did fine for a 30 taper mill BTW.
  1. BT30 Spindle project
    By H.O in forum Vertical Mill, Lathe Project Log
    Last Post: 11-17-2015, 03:05 PM
  2. BT30 Spindle
    By dirtridn2010 in forum Tormach Personal CNC Mill
    Last Post: 05-07-2012, 11:19 AM
  3. Reasonably priced BT30 ATC spindle.
    By dwalsh62 in forum News Announcements
    Last Post: 05-12-2011, 05:59 PM
  4. BT30 spindle - tool changing switch
    By adrianni in forum Benchtop Machines
    Last Post: 04-11-2009, 05:01 PM
  5. BT30 taper spindle for mold making
    By grantmi1 in forum Hard / High Speed Machining
    Last Post: 02-28-2006, 09:41 AM
