586,350 active members*
2,858 visitors online*
    Oct 2007
    9
    What files do I need to backup
    I'm a little confused with file backups on Fanuc controls. Can you just backup the SRAM from the boot menu? Does the SRAM contain the programs, offsets, parameters, ladder, etc.? Do I need to backup anything from the boot menu if I backup everything separately from the GUI side. What do you recommend I backup regularly? Please help me understand the memory side of the controls.
    Aug 2011
    2517
    it depends on the control and how things are stored. as far as I know the SRAM holds the offsets, parameters, PMC parameters, programs etc. everything except the ladder.
    as a general rule backup things separately.
    regular parameters, PMC parameters, ladder. you don't need to re-backup unless something changes in these 3 areas (it shouldn't normally).
    you should already have good housekeeping and have copies of programs stored on a PC or memory card so you don't need to back those up again. and offsets you can easily re-set yourself manually. you could backup offsets if you happen to have a 100 or 200 tool ATC to save time.
    May 2004
    4519
    Back up programs that have been edited at the control also.
    Oct 2009
    297
    If you have a windows screen, you will need to make an image of the hard disk!
    Aug 2011
    2517
    programs running in the control in production should have been backed up before letting them loose on operators. again, good housekeeping :-)
    yeah, backup the OS too including HDD or other OS storage media.
    we would know exactly what if he had not omitted the control type :-/
  1. Converting Illustrator files to Gcode files
    By acoop101 in forum Uncategorised CAM Discussion
    Last Post: 03-10-2023, 11:13 PM
  2. Replies: 2
    Last Post: 01-16-2016, 03:23 AM
  3. Backup ALL files to floppy
    By DEAN in forum Haas Lathes
    Last Post: 12-22-2011, 12:29 AM
  4. Need Backup files for Emcoturn 340
    By rocketcheese in forum DNC Problems and Solutions
    Last Post: 03-27-2011, 03:44 AM
  5. Convert files to Inventor files.
    By bartL in forum Autodesk
    Last Post: 02-04-2009, 06:38 AM
