586,069 active members*
3,845 visitors online*
IndustryArena Forum > MetalWorking Machines > HURCO > NEED HELP! Fault Code x-axis (HURCO VMX24)
    Nov 2012
    Im having an issue with one of my Hurco CNC VMX24 mills. I am a shop owner and machinist myself with great hands on knowledge but this issue is out of my reach.
    Heres my problem:
    The machine seems to run fine somedays, but recently it has been constantly giving me trouble. The machines runs the program i create without any problems, but will stop and shut down randomly while running and even sometimes as its idling. Usually 2 errors pop up when this occurs. The shut down also tends to occur when i press the start button on the control.
    The first and most common error states:
    "SERVO FAULT-X AXIS"
    The second error states:
    ATC ERROR!!! SPINDLE NOT ORIENTED
    I have contacted Hurco Canada and they have sent their engineer twice to try and solve the problem. His efforts were unsuccessful. The first time he mentioned that he directly connected the power (his exact words) and instead of through the connector. The second time he changed some parameters. After doing so each time the machine was fine for a day or a few hours but then the issue would reoccur the next day.
    If anyone has any info, tips or suggestions to resolve this issue id be very grateful!
    Thank you.
    Dec 2012
    What is the drive model on your x-axis?
    What is the alarm on the x-axis drive?
    Apr 2009
    X axis servo fault
    Please contact Hurco 317-298-2635 ask for me Steve, what is your mill serial #. If you contact us we will do our best to help.
    Apr 2009
    Hurco Service
    Do you have mill running? If not please call Hurco Tech Support 317-298 2635.
  1. Hurco VM1 Fault
    By Ph2011 in forum HURCO
    Last Post: 12-20-2012, 06:13 PM
  2. Hurco VMX24 ATC Overload Fault
    By Doug E. Hurco in forum HURCO
    Last Post: 12-27-2011, 08:32 PM
  3. Hurco KM3-P Servo Fault
    By nuzmeed in forum HURCO
    Last Post: 09-26-2011, 04:11 PM
  4. Replies: 8
    Last Post: 09-09-2011, 02:01 PM
  5. hurco vm1 x axis fault
    By merv385 in forum HURCO
    Last Post: 11-23-2009, 09:20 PM
