586,065 active members*
4,327 visitors online*
    Apr 2005
    62
    Machine Spec. advice needed
    All,
    I was hoping someone could give me a starting point on what size punch press to get. We will be stamping out 1/8" knife blanks that are 1.5" x 9". I see punch presses all over the place from 40ton to 500ton. I'm not sure which size I should be looking at. I'm hoping its in the 40 to 50 ton range since they are a lot more affordable. Thank you for your help in advance.
    Apr 2006
    3206
    1 up or multiples?
    Apr 2005
    62
    1 piece at a time.
    May 2004
    4519
    Well, we will assume steel, since you said knife blanks. But material does make a difference. Looks like you have approximately 21" inches. Now find out the shear strength on 1/8" steel by 21" and then double that. I will toss out a wild guess without looking up any data that you will want about 160 tons.
  1. machine coolant advice needed
    By garylb in forum MetalWork Discussion
    Last Post: 09-28-2011, 07:55 PM
  2. vibro burr deburring machine advice needed
    By beekeeper in forum Uncategorised MetalWorking Machines
    Last Post: 05-25-2011, 02:54 PM
  3. help needed, on computer spec
    By paulkane1 in forum Computers / Desktops / Networking
    Last Post: 01-02-2011, 01:08 AM
  4. Absolute minimum machine spec for EMC2 latest build?
    By irving2008 in forum LinuxCNC (formerly EMC2)
    Last Post: 07-24-2008, 12:30 PM
  5. TOROID TRANSFORMER info needed - have spec sheet
    By tekno in forum CNC Machine Related Electronics
    Last Post: 03-10-2006, 02:44 AM
