I just got a new Jcut CNC router 1218A,
CNC Router/Engraving Machine (JCUT-1218A) - China Cnc Router,Cnc Engraver
It looks good mechanically. After I installed NCstudio and set parameters as per Jcut booklet I run my first program. The program run good till half than with no apparent reason the "Y" coordiante moved by 300mm by itself which brought the machine out of the limit.
I unlocked the machine restarted the same progrogram whiout changing anything on the G-Code same Feeds and speeds and the machine run without any problem.
I made a new program and run again and the same thing hapend.
I call the Jcut people and they claimed that the postprocessor is wrong and the speed is high.
I run the machine with programs made with their post and same results.
Always happnd to the "Y".
I suspect thet there is a problem either in the NCStudio or in the controller of the machine.
Does any of you had this problem before or I am the unlucky one?
Or may be there is any setup on the NcStudio that can be done to avoid this.
Thank you
