586,121 active members*
3,497 visitors online*
    Nov 2011
    chuck, door switch not working
    hi i have a colchester tornado 300 lathe the Fanuc controller, the chuck runs ok, but the jaws wont open or close, the door catch will not work, and the turret spins past its position, someone has suggested checking the fuses on the 24v but i cant seem to find them, can you point me in the right direction of how to get all up and going again.
    Kind Regards
    Sean
    24221
    Depends on the type of I/O you have, if you have the remote boards, they have a small green fuse for the 24v.
    Al.
    Albert E.
    Nov 2011
    sorry al
    can you simplify this, i am more mechanically minded than electrically, what do you mean by remote boards.
    sean
    24221
    The I/O is where the various limits switches and solenoids etc plug into, usually via the Blue 40pin Honda Plugs.
    Fanuc have a few variations on the type of I/O from a Rack mounted cards to an oblong shaped circuit board, often fed with a fibre optic cable.
    Al.
    Albert E.
    Apr 2010
    45
    colchester 300
    The problem is you missing 24 V DC
    There are two versions depending how old it is The first one had an E-stop board behind the main disconnect switch on the electrical cabinet usually the relay contact burns on that board.
    The later version has an A-3 board about 10" X 12" and there are 4 fuses on the bottom left side usually one blows because one of the rectifiers in the same area has blown.
  1. Mazak door with switch
    By hutch07 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 10-02-2011, 07:47 PM
  2. DOOR SWITCH
    By tcarter000 in forum Cincinnati CNC
    Last Post: 01-07-2010, 04:42 PM
  3. Door switch removal?
    By Donkey Hotey in forum Haas Mills
    Last Post: 09-30-2008, 05:17 AM
  4. Haas VF2 Door Switch
    By Highrod34 in forum Haas Mills
    Last Post: 04-16-2008, 04:20 AM
  5. Door switch on Torque Cut
    By Gncc50 in forum Bridgeport / Hardinge Mills
    Last Post: 02-06-2007, 04:38 PM
