586,032 active members*
2,993 visitors online*
    Nov 2012
    Torch won't fire
    Hi, my name is Amanda. I'm the secretary here at Heiss Welding. And, we're having a problem with our Plasma Table. We're using a powermax1000 on a floating head. We're hooking up the height control now, and we ran into a problem. We've installed the Rev-01 Voltage divider in our Powermax1000, connected the THC Sensor PWM module between our Bladerunner Dragoncut and the powermax1000 as specified in the manual. However, when we go to test the torch firing circuit and press both torch fire buttons on the RAV-01 card we do not get an arc. We've checked the continuity, we're not getting any. We're not getting any signal to fire the torch. When we jumper-ed the torch it worked fine, but we're stumped. Any help would be appreciated.
    Jan 2008
    2247
    The best bet is to contact the manufacturer of the Bladerunner kit www.candcnc.com , there is either a wiring error or a setting in the setup files that may be incorrect. Should be easy to solve.
    Jim Colt Hypertherm
    Quote Originally Posted by HeissWelding View Post
    Nov 2012
    We also have a plate marker, and haven't been able to find much information on the setup for it. If anyone has a manual to link, it would be appreciated.
  1. CANT GET MY TORCH TO FIRE
    By monolithfs in forum Plasma, EDM / Other similar machine Project Log
    Last Post: 09-29-2011, 06:43 PM
  2. fire clay/fire rock
    By banctecbobn in forum Casting Metals
    Last Post: 12-12-2009, 11:14 PM
  3. Should torch always be over metal to fire ?
    By bad-rat-57 in forum Waterjet General Topics
    Last Post: 07-10-2008, 02:01 PM
  4. Epilog Fire Torch Mag file
    By Micheal Donnellan in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 02-15-2008, 03:59 AM
  5. Cannot get my torch to fire?
    By Redline in forum Waterjet General Topics
    Last Post: 08-27-2006, 03:45 PM
