Originally Posted by
cierva
Hi Guys ...---... O.S.O.
I am in need of you help, like most I have purchased a Chinese laser cutter
In the beginning this worked great.
I build and fly model aircraft; short time back I was using the machine to cut out a new model it got half way through the pattern it was doing and it went bang..............?
On checking the power it had tripped off for the machine.
When I switched the machine back on there was no display, no movement in
The X & Y axis it was dead.
I contacted the manufacture explained what had happened, after many emails
They explained that what had happened was when it went bang ,
it has taken out the main control system also the laser power supply.
As the machine is about 3 years old they advised it was using the old style control
System and this had been upgraded within the last three years to a much better
System...........?
As this was very urgent I was decide that a new control system was needed , many more emails and a new control system came , as for the power supply I had a spare one , they sent a lot of information on fitting the new control system , the new control system has been fitted and the machine is again “ alive “ all function are working but one what ever I try : I can not get the laser to fire
I have to admit I am not very good with electrics but I can follow info when it offered as per the manufacture had offered as the machine again back on line
I have double checked all the wiring as per there instructions it . the display says
It is working but its not, also it will not fire manually, I am at a complete loss of what to do.
The model I was cutting was to be in completion this year and the parts are not possible to cut by hand.
Any help you guys can advise would be very gratefully received.
Alan
