586,060 active members*
3,492 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Biesse > Biesse Rover J FT TP suction box movement timeout
Results 1 to 2 of 2
    I've recently taken over all the CNC duties in my workplace, I'm up to speed when it comes to general operations but maintenance and error messages are still somewhat of a mystery to me (so apologies if the solution is obvious!)
    I'm running the machine to alternate boring a selection of holes and then milling slots for dominoes between these holes. Normally I'd do all bores first and then all millings but for this project it makes sense to alternate, in this instance it's meant to repeat the process 11 times. It completes the boring with no issue but every single time it completes a line of slot milling it stops and throws up the error code "PLC95847 TP suction box movement timeout (1;1; in 992)".
    Please take a look at the attached pics, I've been told it relates to this part of the machine, which has definitely taken a beating and may be in need of fixing/replacing but I thought I'd ask around first. Could it be anything else? Does anyone know the name of this type of part and where I can get a new one? It is also asking for a slot reset every time and not always being very responsive when I click it. Any advice is welcome, no matter how simple or obvious you think it is. Thanks.
    Nov 2011
    21
    Re: Biesse Rover J FT TP suction box movement timeout
    Hi Smolstuff,
    according to the error you have problem with suction box (movable folding cover around milling tool). I can't see any picture... However after the tool finishes job, this cover goes up and activates sensor to say "I am UP". It seems that it goes up too late or not completely, you should check if it is well fixed and clean from internal side.
  1. cnc biesse rover 36
    By ylbermuhaxhiri in forum CNC Machining Centers
    Last Post: 01-30-2019, 10:30 AM
  2. Replies: 13
    Last Post: 10-21-2017, 06:02 PM
  3. Biesse Rover 322
    By domin240 in forum Biesse
    Last Post: 08-27-2017, 01:10 PM
  4. Biesse Rover suction pads suck
    By majstor76 in forum CNC Machining Centers
    Last Post: 04-22-2009, 06:19 PM
