OK I am rebuilding this Bridgeport V2XT
all the details are here
http://www.cnczone.com/forums/bridge...c_bp_v2xt.html
Now that I am about to mount the Automation direct GS2 VFD which will be controlled by a CNC4PC C32 card I was looking into Spindle pulley profiles via MACH3. Why do I need a pulley profile? Because of the back gear. That has a proximity switch that I want to wire in as an input that tells the program it can continue when a speed below 1088 RPM is called up by the part program ( I guess I have to make a brain for that? ). I take it that in the pulley profile I can tell MACH3 that the first profile is good for a certain RPM range and anything below that needs the other range and for the spindle to be reversed.
I also have another issue I would like the Analog output to command the VFD for 30-240 Hz in High gear and from 30-250 Hz in low gear ( So I don't get a gap between back gear and main gear)
Does MACH 3 remind teh operator in the middle of a program to make a "pulley change" when needed? I'd love to hook up sound for that cycle complete, tool change, and Gear change.
Anyone have any suggestions? Anyone out there already dealt with this problem on a knee mill? Thanks for the input.
