586,106 active members*
2,919 visitors online*
IndustryArena Forum > CAM Software > SprutCAM > Using a drilled hole to start a pocket
Results 1 to 6 of 6
    Jul 2003
    148
    HI, is it possible in sprutcam to use a drilled hole as the starting point for a pocketing operation?
    Nov 2010
    45
    I was wondering this too. I know you can drag the lead-in around, but I haven't gotten around to trying to drag it all the way into a drilled hole. Not sure the path would recalculate sufficiently. I'll try that sooner or later, I'm not working on anything suitable at the moment.
    Feb 2008
    389
    Hi Scott and Spoog,
    I use Roughing Waterline and pick the bottom of the pocket under the Job Assignments Tab and click on Pocket.
    Then click on Holes Tab in the same icon row that Job Assignments is in and click on an inside surface of the hole and click on center over in the Holes tab.
    Then go ahead and finish the rest of the operation settings.
    I attached a SC7 project file and hopefully the screen cap will help too.
Name:	Capture ScottS Hole Start.jpg
    I should add that you can do the same (assign a hole) in a pocketing op as well.
    Attached Files Attached Files
    Currently using SC7 Build 1.6 Rev. 64105
    Feb 2008
    389
    Creating a hole to start a pocketing tool path
    I thought this may be helpful to some people too.
    Say you don't have a drilled hole in your model to start your tool path but you want to start your tool path in a specific location in the pocket.
    You can follow the same steps as I described above but instead of clicking on "Center" click on "Create" and using X,Y coordinates to place a "hole" where you want the tool path to start.
    Attachment 193106
    i was learning IT TOO, but till now no answers, maybe you can try to contact the suppliers from China , they may help you some tech supprt,
    i find a guy here China professional manufacturer of laser machine and cnc router. , hope can do help to you , good luck.
    Nov 2010
    45
    Bit of a delayed response, but I've come back to this now.
    Gerry, thanks for the explanation and example, I see how it works now.
    I'm slightly surprised the operation doesn't seem to interact particularly with a previous drill op and/or create it's own drill operation, but it doesn't really matter in the end.
  1. Starting cutter in a drilled hole??????
    By ross33912 in forum Mastercam
    Last Post: 02-26-2013, 07:35 AM
  2. runout on drilled and reamed hole in lathe
    By photomankc in forum Benchtop Machines
    Last Post: 06-28-2012, 06:21 PM
  3. Multiple diameter step drilled hole.
    By frogier in forum MetalWork Discussion
    Last Post: 03-28-2012, 08:21 PM
  4. Replies: 5
    Last Post: 04-07-2011, 07:26 PM
  5. Fastest Hole drilled yet
    By Magnum164 in forum Tormach Personal CNC Mill
    Last Post: 02-28-2011, 11:53 PM
