I am in the midst of a CNC conversion to my IH mill. As part of the conversion, I am switching to belt drive.
This means that the mill head will be drained of all oil, the gears will be gutted out an the cast head cover removed - thus removing some weight. The belt drive assembly will then add approximately 22-25lbs back into the head assembly.
My real concern is the weight of the new motor. I have found two motors - one that is a real gem and the other that meets most of the requirements. The trouble is that the better motor weighs in at 102lbs, while the other weighs 62lbs.
I will be using 850oz-in servos through a 3:1 pulley reduction, so I'm confident there will be plenty of torque at the ballscrew. I guess I'm just wondering if the weight of these motors is excessive and something that I should be concerned about with the setup I have described. If it's not deemed excessive, my preference would be for the heavier of the two motors, but would go to the other motor if the general consensus was that the weight was too high.
Thanks for any help.
-tulsah
