586,745 active members*
6,040 visitors online*
    Nov 2004
    19
    Citizen Cincom e32
    Help,
    This is my 1st mill turn machine. Have no documentation on what the post should look like on this citizen 32. Have 3 live tools to use and will use both spindles.
    I also have a magazine bar feed to be programmed in addition.
    Any help would be awsome.
    Patycoop
    Oct 2012
    60
    Quote Originally Posted by patycoop View Post
    Help,
    Patycoop
    Post some geometry and a simple program with all the required elements you want in it and I'm sure the Mazak Integrex (Mill-Turn) post processor could likely be modified to generate the G-Code specific to your machine.
    Nov 2004
    19
    Samle part like I will be making.
    Attached Files Attached Files
    Oct 2012
    60
    You still need to provide some kind of sample G-Code to work off of. I'll try and modify the post. I'm not familiar with the type of code that the Cincom E32 uses. Please provide any documentation you have or can find (including google searches) because that's the only way I can know how to adjust it for your specific machine. We'd need to know codes like how to change tools and turn live spindles on, coolant, etc.
  1. Need Citizen Cincom G32 Operation Parameter
    By Donatello Tam in forum CNC Swiss Screw Machines
    Last Post: 07-22-2022, 02:53 PM
  2. cincom citizen L20/3M7
    By mustijo in forum CITIZEN Machines
    Last Post: 02-01-2019, 11:20 PM
  3. L20/L16,3M7,CINCOM
    By sepganesh in forum CNC Swiss Screw Machines
    Last Post: 02-26-2012, 06:27 PM
  4. Want to buy used CITIZEN Cincom L20E Type IX (L720EIX)
    By MarcvonAmsberg in forum Want To Buy...Need help!
    Last Post: 09-13-2011, 09:47 PM
  5. Need Citizen Cincom G32 Operation Parameter
    By Donatello Tam in forum Controller & Computer Solutions
    Last Post: 04-26-2008, 01:54 PM
