586,069 active members*
3,425 visitors online*
    Jul 2003
    36
    Stepper motor question
    I have 4 of these stepper motors and was wondering if I can use them for a 3D printer like a PrintrBot.
    12 Volt
    .30 Amps
    40-oz-in torque
    1.8 deg step
    40 ohm
    NEMA 23 frame
    6 wire
    Sam
    Jan 2010
    2141
    I have no direct experience with the PrintrBot.
    But here are a few notes anyway.
    First, the physical size of NEMA 23 motors is larger than the NEMA 17 motors that (apparently) are typically used for the PrintrBot. So it is possible that you may run into difficulty (or may have to make adaptations) when mechanically mounting the larger motors.
    Also, it appears that the PrintrBot uses 4 motors for controlling the X, Y, and Z axes (two motors are used for the Z axis) plus a fifth motor which is required for the extruder. So you would need to find a fifth motor.
    The motors that you described do not have a lot of torque (but then typical 3D printers require less torque than typical CNC routers or milling machines or lathes because the weight that must be moved by the motors is much less). It would be a good idea to find out whether the PrintrBot design specifies the minimum torque rating for the motors.
    The '40 ohm' spec that you listed sounds high to me - are you certain that you have listed it correctly?
    6-wire motors should be OK (but how you would hook them up would depend on the specifics of the motor drivers that you would be using).
    CUTCNC Guest
    I think you had better to ask the PrintrBot after sales service people
  1. Stepper motor question
    By Dman65 in forum DIY CNC Router Table Machines
    Last Post: 09-17-2011, 03:31 PM
  2. Stepper motor question
    By QSPSB in forum Benchtop Machines
    Last Post: 09-24-2010, 03:27 PM
  3. Stepper motor question
    By Almaz in forum Stepper Motors / Drives
    Last Post: 10-05-2008, 11:51 PM
  4. Stepper motor question
    By alexis221 in forum Servo Motors / Drives
    Last Post: 10-06-2007, 02:29 AM
  5. stepper motor question
    By starCNC in forum CNC Machine Related Electronics
    Last Post: 05-04-2004, 11:06 PM
