586,075 active members*
4,218 visitors online*
    Dec 2005
    160
    minor annoyance mach3 and geckos
    Im setting up a plasma table with mach, 4 gecko g201 drives and steppers. my breakout uses the charge pump
    Im testing my x axis for now, mechanically everything is on the money i get smooth movements and great repeatability. The annoyance is when I power up and press the reset button in mach3 the stepper motor moves a step and and if I keep pressing reset it will move. Now when I jog the axis then now press reset the axis works properly and does not move when pressing reset.
    any way to prevent the motor from moving during the mach3 start up?
    Jan 2006
    2985
    After powerdown, you cannot be sure the machine is in the same place it was left. The proper way is to home the machine after each powerup.
    Matt
  1. AD tutorial annoyance (nit)
    By jviss in forum Uncategorised CAD Discussion
    Last Post: 01-30-2011, 12:48 AM
  2. SprutCAM 7-- Now It's More than an Annoyance!
    By dkaustin in forum SprutCAM
    Last Post: 03-11-2010, 03:07 PM
  3. SprutCAM 7 Annoyance #1
    Last Post: 03-04-2010, 04:47 AM
  4. Mach3,Geckos,DC Servo & Stepper Problem
    By wjfiles in forum CNC Machine Related Electronics
    Last Post: 12-15-2009, 07:41 AM
  5. Milltronics Error 450 E-stop annoyance
    By M_Controls in forum Milltronics
    Last Post: 09-20-2007, 03:14 PM
