Originally Posted by
brcguy
Thanks, I am on a concrete/tile floor.
I've done the work of making sure the mirrors are all in the same plane (s) and it should be all level and nice.
My alignment procedure is to replace the each mirror with an acrylic target (cut on the laser with cross-hairs engraved on it) and use the laser to fire a mark to see where it is hitting. I go through a lot of targets, but it seems to work.
My Full Spectrum has a rigid third mirror, this one does not, and I am not sure of the best way to align the last mirror into the lens. For instance, where do I put the cross-hair? Do I use the lens or not?
I have used the levelling trick on my Full Spectrum, but the Transon laser has a fixed height table and an adjustable height lens. I will try your trick of gauging the surface and see what I get. I will probably have to shim the table to get it level if it is not already.
Thanks for the reply. I am deep in production mode right now and need all the capacity I can get.
