586,516 active members*
3,829 visitors online*
IndustryArena Forum > Mechanical Engineering > Linear and Rotary Motion > Anybody successfully managed to straighen a ballscrew
    I have a DIY laser cutter that uses two 15mm diameter 20mm pitch ballscrews to drive the y-axis.
    My trouble is one of the screws is badly bent and because the machine is so lightly built the bent screw is moving the gantry and causing a wobble to appear.
    I would like to try and bend the screw back into shape. Has anyone had any luck trying this themselves, if not where should I be looking to find a pro to do it for me and what should I be looking to pay. Bear in mind the screws themself cost me £80, cheap enough to attempt a staighten myself.
    I have been practicing with some 10mm stainless steel rod. It is proving difficult to get it anywhere near staight. My setup is a pair of vee block and a dial test indicator and a relatively straight cast Iron table of my belt sander.
    Aug 2011
    388
    It's possible but not easy. I was able to improve one, but couldn't get it super straight. I rolled the shaft on a surface plate to try to find the bend point. Rolling half-on and half-off helps narrow the problem zone. The trick, of course, is to apply just enough force to bend it but not over bend. "Calibrated" dead-blow hammer strikes can work, or if you have a milling machine, use the z.
    This is how the pros do it:
    [ame="http://www.youtube.com/watch?v=Vg7KHaHd9I4"]Eitel RP-16 straightening press - ballscrew demo - YouTube[/ame]
  1. How do I cut Kevlar Sheets, successfully?
    By sledgecraft in forum Glass, Plastic and Stone
    Last Post: 02-03-2012, 06:41 PM
  2. Replies: 2
    Last Post: 06-09-2011, 07:48 AM
  3. Anyone successfully backed up their hard drive?
    By padyakbud in forum SIEMENS -> GENERAL
    Last Post: 05-19-2010, 05:31 PM
  4. Update: Have managed to fix one of the errors.. still got one more.. anyone?
    By DesKitchens in forum Commercial CNC Wood Routers
    Last Post: 09-15-2009, 08:29 PM
  5. Anyone successfully model a guitar neck?
    By rlrhett in forum Musical Instrument Design and Construction
    Last Post: 03-14-2009, 06:56 PM
