Hi, new to this forum and I could use some help. I'm building a cnc router with travels of 48"x48" I'm using 8020 for most of the project. Right now I'm confused about linear motion of X and Y, I've seen comments about linear bearings and shafts. Is it realy hard to get these without the problem of them being bent? I'm planning on using 20mm rods, is this adequet for the approximatly 60" length? I want to be able to run aluminum panels without any problems once the machine is complete. I plan to run 2 ball screws on the Y axis and 1 ball screw on the X, any suggestions as to what size to use to prevent whipping? Also is there much of a difference between mounting linear parts on top of rail or on the side? Any suggestions will really help. Thanks
