Hey guys, been looking around the board the last couple days and after finding some answers to problems i hit a big snag.
I work for an educational institution, we recently had an Arrow 750 donated, it has a Siemens Acramatic 2100, with a Vickers controller. The machine was working fine, it was powered down over the recent holiday, and when it was powered back up we had an error.
We called in a local machine tool shop guy and he deemed the battery on the mother board dead. Sure enough when the voltage was checked it was well below battery voltage.
After changing battery the machine runs threw its boot setup, detects the hard drive, and attempts to boot. upon booting things happen in this order.
Screen goes black and message "Ntdetect..." with dots appearing on the screen
Message appears below saying a problem is detected and to press space bar to revert to a previous setup, weather space bar is pressed or not pressed systems continues
Screen turns blue with white text and appears of loading windows NT
Screen changes to a screwed up black and white screen, a pixelated hourglass appears in the center of the screen and the screen freezes.
I would post pictures but I am getting this second hand.
I am being told windows NT has been corrupted and the hard drive needs to be replaced. I am told this cost $$$. Anybody know a possible lower cost solution rather than getting a new pre-loaded hard drive? Or perhaps has run into this problem before and might be able to suggest a different solution.
