586,655 active members*
2,852 visitors online*
    NO z movement on 11M
    so i was gone a week and come home and Z will not move .. (x and y work fine )
    its on a accumax if i remember correctly .. mill m11 control
    tried MPG and jog buttons ..
    cant do from a program because not homed ..
    have tried OT release , and pushed all other buttons a few times to make sure none are sticking ...
    head is about halfway done the mill ..
    made sure all limit switches were not stuck ...
    i swapped the top servo amp board with another and no difference .
    both leds on the drive are green ..
    idk if it is supposed to say anything but main mother board says 1 on the display .
    tested all fuses ..
    the servo is getting power , IE it has holding torque
    checked the brushes , looks to be 3/4 long or more .
    going to take apart all connectors and spray them with cleaner tomorrow ..
    what else could it be ?
    www.wildhorsemfg.com machinist / gunsmith
    accumax with Fanuc 11M , Hitachi seiki 3NE with 6T
    Apr 2009
    108
    It sounds like the Z-axis interlock is low. Most likely a tool changer limit or tool clamp limit not made.
    Nov 2007
    188
    is there a Z neglect botton
    found the problem , it was the toolchanger ..
    air cylinders must be sticky and dont always return all the way home .
    i didnt think it was Z neglect ,, becuse when that is on .. the numbers move without movement ...
    i had no number movement .
    thanks
  1. I don't have any movement
    By sml2010 in forum Engraving Machines
    Last Post: 01-03-2013, 06:55 PM
  2. No movement after G00
    By slatronic in forum Mach Software (ArtSoft software)
    Last Post: 07-03-2012, 02:10 AM
  3. Erratic Z movement AND NO X Y MOVEMENT
    By 05miata in forum Mach Mill
    Last Post: 06-04-2012, 03:10 PM
  4. Help! - No Movement
    By jeremysartor in forum Mach Software (ArtSoft software)
    Last Post: 12-12-2010, 07:37 PM
  5. no x y z movement
    By bullseye in forum CamSoft Products
    Last Post: 07-29-2010, 02:39 AM
