Thsat should be a great machine, as long as you take somewhat light cuts and with 3000RPM and CNC you can take a lot of cuts very quickly.
My CNC lathe has pretty well the same turret toolpost, it is very slow toolchange and you have to be carefull to pick your toolchange spot where you wont swing your tools into things you dont want to.
At $13000 it is pretty much a disposable machine and you should try and figure your payback over a 5 year term. With proper care it will last much longer than that, but I would still make sure to be ready to replace it just in case.
www.integratedmechanical.ca
