586,103 active members*
3,594 visitors online*
Results 1 to 12 of 12
    Jul 2005
    28
    Aluminum extrusion
    I would be interested to hear what the community thinks about this Kickstarter project. I'm not the owner of the project I'm currently just a backer at the lowest level.
    does this look feasible?
    Sent from my SCH-I510 using Tapatalk 2
    May 2010
    93
    Is there a link?
    Sent from my DROID RAZR HD using Tapatalk 2
    Sep 2012
    1543
    I went to kickstarter and searched for aluminum and found it, along with everyone making aluminum pens and making 16,000$...... Really.... I think its time to make A pen...
    Jul 2005
    28
    http://www.kickstarter.com/projects/...ned-for-makers
    Herein the link
    Apr 2005
    419
    I think it is a reasonable step forward from makerslide.
    Similar but slightly more robust with the steel inserts.
    I feel like there are already too many linear motion solutions to keep track of, but this one certainly seems like a compelling choice.
    Feasible for what?
    Looking at the picture, it appears that the steel inserts are only supported by a 1/8" web, which would make it not very strong if trying to get a lot of preload on the V bearings.
    May 2010
    93
    It looks to me like it'd do well for for 3d printers, or otherwise light loaded setups. It's not something that I'd put into a machine that has any kind of heavy loading.
    Jan 2008
    853
    Feasible for what?
    Looking at the picture, it appears that the steel inserts are only supported by a 1/8" web, which would make it very strong if trying to get a lot of preload on the V bearings.
    Gerry, did you mean to say 'not very strong' ?
    Paul Rowntree
    Vectric Gadgets, WarpDriver, StandingWave and Topo available at PaulRowntree.weebly.com
    Yes I'll edit it.
    Mar 2011
    584
    As said above I don't see it being very strong, good for 3d printers and laser kits but I would think makerslide would be cheaper and do the job just fine. I see one big problem with it in that if they don't include the steel I could see someone sourcing their own and having problems with it not fitting correctly...
    Jul 2005
    28
    It looks like they will have options which include the steel along with the aluminum.
    I'm just looking for something to replace the akatw bearings/1" pipe on my JGRO.
    Apr 2009
    5516
    Quote Originally Posted by ssgtbair View Post
    You probably could find used profile rail on eBay for cheaper, and you don't have to wait an eternity for the kickstarter to raise enough money... if he ever does. Like Gerry says, it's not donfigured in the strongest way. Using extrusion with 2 or three slots might have made more sense. Then again, using CNC Router Parts carriages and CRS bar seems sturdier, easier, and cheaper than this.
  1. aluminum extrusion
    By georgebarr in forum DIY CNC Router Table Machines
    Last Post: 05-14-2013, 09:03 AM
  2. Aluminum extrusion
    By Pysiek in forum RFQ (Request for Quote)
    Last Post: 07-21-2012, 05:20 PM
  3. 4'x4' Aluminum Extrusion and Hypertherm
    By tjb1 in forum Plasma, EDM / Other similar machine Project Log
    Last Post: 06-24-2012, 04:09 AM
  4. Looking for a Source for Particular Aluminum Extrusion
    By TaK in forum T-Slot CNC building
    Last Post: 01-06-2012, 04:56 PM
  5. aluminum backward extrusion
    By llilrex in forum Bending, Forging, Extrusion...
    Last Post: 04-04-2009, 06:06 AM
