586,058 active members*
4,281 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > feed and speed for high speed
    Nov 2012
    162
    Sum Dum Guy here again. I've been looking at high speed coding using the adaptive roughing feature but came across a small problem.
    I know Bo9bCAM has built in speeds and feeds for regular machining but where do you get the speeds for high speed?
    One of the guys here offered 931 surface speed, 7500 rpm, and 60 ipm cut rate. How did you come up with these numbers?
    Sorry for all the trouble I'm putting you guys thru but I gotta learn somewhere1
    Thanks again guys, you really a big help.
    Apr 2009
    3376
    Apr 2008
    1577
    Tooling manufacturers will usually supply their own data. If they don't, buy different tools.
  1. High speed spindle... how high?
    By jonesja2 in forum Uncategorised MetalWorking Machines
    Last Post: 10-06-2015, 04:37 PM
  2. High Precision, High Speed Bearings
    By mikeyg in forum News Announcements
    Last Post: 09-08-2009, 01:06 AM
  3. Any one using Tormach in high speed feed rate?
    By madaouk in forum Tormach Personal CNC Mill
    Last Post: 12-24-2008, 01:14 AM
  4. Replies: 10
    Last Post: 09-08-2007, 05:40 AM
  5. mach2 i can jog at a max speed of 30 ipm but it wont feed that high?
    By mike10 in forum Mach Software (ArtSoft software)
    Last Post: 03-21-2005, 12:28 PM
