586,104 active members*
3,418 visitors online*
Results 1 to 3 of 3
    Oct 2004
    29
    Question Uneven traven
    Hello everyone,
    I am working on a Grizzly G8689 mini Mill turning it into a CNC. Nema23 200oz/inch steppers, Mach3 control SW and the CNC conversion from CNC Fusion. The problem I am having is that there is uneven travel between the negative X direction and positive X direction after I calibrate the Mach3 SW and the Mill.
    Calibrating the X axis over a 1" distance without Backlash compensation, I can get X to travel in both directions but the negative direction is spot on and positive direction is under by .017". With Backlash enabled, the negative travel is .003.5" over and the positive travel is about .014.5" under. I can split the difference but I'd really like the X to accurate to +/- .001" in both directions.
    Does anyone have any advise as to where to look for this slop?
    Thanks for reading and responding
    CE
    Feb 2012
    234
    Try moving from positive to negative see if you have the same amount of backlash. if so try tightening up on the jam nuts.
    Oct 2004
    29
    Quote Originally Posted by Whizbang View Post
    The Locking Screw that holds the Aluminum ballnut had worked lose and the gib nuts were also a little lose.
    Thanks Whizbang. I lost a Motor drive in the process (Maybe it got a little cold in my garage) so I'm down for a few weeks.
  1. Uneven table compensation
    By crane550 in forum DIY CNC Router Table Machines
    Last Post: 09-05-2017, 08:47 AM
  2. V-Carving Uneven Surfaces
    By rab in forum Uncategorised CAM Discussion
    Last Post: 12-05-2011, 05:04 PM
  3. Layout For Uneven Surface
    By shaun091382 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 02-22-2011, 04:48 AM
  4. Engraving and uneven surfaces
    By phatjap in forum DIY CNC Router Table Machines
    Last Post: 04-21-2010, 01:11 PM
  5. Uneven finish
    By orbyog in forum Mach Software (ArtSoft software)
    Last Post: 02-05-2010, 08:42 PM
