Well, I've posted part of my story on other threads when asking questions or something, but it was about time I made a build thread, if anythIng to keep my crazy ideas in one place..
It all started about this time last year when I started seeing DIY 3d printers and mini routers all over the place. I've always been fascinated with automation and CNC in particular, so I was hooked right away! I started buying parts and making plans for a crazy router/printer combo machine and soon ran into a sieg X2 and a 7x12 lathe selling locally pretty cheap. "Well those could be useful.."
Not only were they useful, I fell in love with making chips! In a couple months, I sold the mini lathe and bought an old 12x40 Clausing, and kept looking for a bigger mill.
At the time, I was working for a big film post production company. They had a film lab and a small machine shop that supported and maintained the lab. By chance, I happened to tell one of the engineers that I was looking for a larger mill and he told me the lab was shutting down and they'd be selling everything off. A few weeks later he called me one morning and offered me their RF40 for $400. I couldn't pass on that, even if I didn't like the round column.. It came with a little bit of tooling and a big metal workbench.
But the best was yet to come! In the following weeks, they gave me hundreds of dollars worth of bearings, metal stock, motors, servos, power supplies, a VFD, taps and other random tools. It was like Christmas every couple of days, as they dug through their stuff and called me to come pick up the goodies.
At this point, I had a gecko g540 based controller that I had bought for my initial weird router plans and some 425oz steppers. I quickly got the machine running with the stock leadscrews and used the quill as my Z axis, with a pulley on the stock fine feed screw. I wanted to make sure everything worked before I spent a lot more time and money on ballscrews, etc.
I used the machine like that for a few months, and started making x and y ballnut mounts for the Chai eBay ballscrews, which were on order. But I wasn't happy with the limitations of having the quill as a Z axis, 5" of travel wasn't enough and I found myself having to crank the head up and re-zeroing quite often. I know, I know, poor planning on my part, but if definitely wasn't great.
So I started making crazy plans again, was looking around for a big piece of steel column I could weld and machine into a column, and I already had some linear rails I could use to mount the head to the new column. But in a strike of genius (or pure luck) I decided to email one of the RF45 vendors to ask if they happened to have a spare column around.. No, he didn't, why the hell would he have a spare column lying around.. BUT he did have a brand new RF45 that was almost complete but missing a table, motor and leadscrews.. And he'd sell it to me for $500. I said no, I didn't need an entire mach... Wait, did you say $500? Oh.. Well, I guess I COULD use another head, and maybe the bigger RF45 base wouldn't be a bad thing.. Ah! I'll take it! I had heard good things about Pat at Machine Tools Warehouse, but this was incredible. His service was great and I know I'll be buying more stuff from him in the future.
And so we arrive at the current state of things. The plan now is to get the RF40 working with the ballscrews (more on that in a minute) and use it to do some major surgery on the RF45. I'll be converting the 45 head to belt drive and mounting the 3phase motor/VFD combo and finding a way to stick a ballscrew inside the new square column. Then I'll move the square column to the current RF40 base.
The second part of the plan will be to use the RF45 base, which has significantly more Y travel. My current 40 with the ballnut in Y is limited to 6" of travel, although I plan to cut away some of the base webbing and hopefully get closer to 8 inches. The 45 base has at least 9", possibly more! There is a problem though. Since I don't have a table for the 45, I'll have to adapt something somehow. The saddle on the 45 is bigger, so the table doesn't fit the bigger saddle. And the smaller saddle from the 40 has a different dovetail angle, so it also won't work on the new base. My current crazy idea is to, at some point, mount the RF40 table on the 45 saddle with linear rails, rather than using the dovetails. I have radial style rails that would be perfect for it.. And I'm tempted to do the same for the saddle, but the base is perhaps a bit too big to machine at home.
Lastly, to end this really long, boring post - with the stock leadscrews I was only getting around 40IPM before the steppers would stall randomly. The 425oz steppers were a poor choice, I now realize, as they lose torque very quickly as RPM goes up. But with the ballscrews, the increased efficiency and the fact they're around 5tpi (25mm pitch) rather than 10tpi (which means the stepper is spinning slower for the same IPM rate, where they have more torque), I was happily moving the table around at 120ipm last night. And I haven't even oiled the ways (I know, I know..), I couldn't resist trying it out. I will likely keep rapids at around 100ipm to have some margin, but I'm thrilled with the improvement.
I apologize for the long post, but well, now you know as much as I do! Pictures to come at some point, I'm not a very enthusiastic photographer, but I'll snap something to make the thread a bit better!
Thanks for the tips, advice and inspiration so far, this place is incredible.
