after enableing I get the following error code
Motor fault ( 0x 17 )
Drive 1 ( XA )
Teknic Comm Error.
Can anyone explain this to me?
Please point me in the right direction
Drive 1 ( XA )
Teknic Comm Error.
You servo drive could be failing to establish comms with your control board, depending on which control board you have, you could move cables around and see if the problem moves or does it stay with the drive.
Can you tell me if your machine has a blue control board and is labeled 2521?
yes it's blue 2521
Give me a call, you can actually move your cable around and with your control board reprogram your drive to try to narrow down if it is the drive or the programming.
Maurice Phelps
678-548-1483
Yes, I installed your machine.
