586,103 active members*
3,822 visitors online*
    Oct 2012
    Bearing in a block
    Hello,
    I have a rookie question: to accomplish a bearing setup like this one (from a build thread) how do you keep the inner band of the bearing from rubbing?
    Istvan.
    Oct 2010
    71
    A little bit picky but the shaft on the ballscrew would need to be turned down to a plain section from before where it enters the bearing to the correct length for where it goes into the stepper coupling.
    As for rubbing do you mean the screw part of the shaft rubbing the inner bearing ring or the inner bearing ring rubbing against the mount?
    The shaft would normally have the screw part turned down to a plain section then it would have a spacer ring between end of the screwed section and the bearing allowing it to rotate freely. If the inner ring is rubbing against the mount then make the inner hole in the mount bigger to allow clearance of the inner ring and shaft, the outer ring of the bearing will support the load. Whats the coupling on the right hand side of the bearing mount for?
    Mar 2006
    2712
    Why not just use a pair of inexpensive angular contact bearings like the rest of the world? That would radial and axial support in a less complicated set-up than the one in the link.
    Dick Z
    DZASTR
    Oct 2012
    Hello, thanks for the reply.
    Quote Originally Posted by RICHARD ZASTROW View Post
    Dick Z
    I am not familiar with bearing shopping, but on mcmaster the cheapest sealed bearing for my screw (.5") is this one:
    6680K34
    That is $126.10 -- is there something else I should be looking for?
    Regards,
    Istvan.
    Oct 2012
    179
    The drawing shows 2 thrust bearings that are held by the set collar and coupling. I would imagine that there would be enough contact area if this were clamped to a fine enough lead screw but I don't believe it would work on a ball screw. The key to any design is to minimize the shifting of the screw within the mechanism which translates to backlash. That design consideration is balanced against the increase in friction associated with high preload in the bearing system. You could use angular contact ball bearings (they worked on 57 chevy front wheels) or tapered roller bearings. If you want to have the thrust taken up on only one end of your screw then a 2 row ball bearing would do the trick.
  1. Z bearing block
    By In-Spec in forum Joes CNC Model 2006
    Last Post: 01-17-2010, 07:15 AM
  2. How to cut a bearing block ?
    By ringram2077 in forum MetalWork Discussion
    Last Post: 04-03-2008, 03:49 AM
  3. Air Bearing Block-Head
    By Zathras in forum Want To Buy...Need help!
    Last Post: 02-21-2008, 05:12 PM
  4. Help with bearing block
    By margni74 in forum Linear and Rotary Motion
    Last Post: 08-11-2007, 10:47 PM
