586,082 active members*
3,541 visitors online*
Thread: Gantry
    Oct 2011
    Gantry
    can anybody help with gear reduction. I bought nema 23, 0.375 bore,600 rpm and 620 in. oz torque. Gantry will be all alum. approximately 100-120 lbs. I bought candcnc controller and the recommendation is to have 1 rotation = 1" gantry movement. I would like to have belt reduction to rack and pinion.
    Info needed:
    XL Timing & Pulley Belt Size
    What would be the best Rack & Pinion
    Jun 2006
    43
    I think you have posted in the wrong forum, try the mechanical engineering, calculations, design or the linear and rotary motion forums.
    Post people use 20° pressure angle, 20 pitch racks, with a 1" diameter pinion geared 3:1.
    This will give you just over 1" per motor revolution (pi/3).
  1. Gantry
    By CharleyDavidson in forum Linear and Rotary Motion
    Last Post: 02-22-2012, 08:21 AM
  2. New XYZ Gantry Kit
    By dfmiller in forum XYZ Gantry Routers
    Last Post: 10-11-2011, 06:03 AM
  3. Gantry: planning to design moving open gantry
    By rdcd in forum Mechanical Calculations/Engineering Design
    Last Post: 11-14-2009, 10:52 PM
  4. Replies: 2
    Last Post: 09-15-2009, 05:09 AM
