There were different versions of each, the 0 was the small work horse version and spanned a few of the other versions, such as the 10 and on etc.
All version are purchased initially with the required options, most of these are in the control but have to be turned on by changing a 0 to a 1 in the option parameters.
Drip feed again depended on the version and whether the ladder had to be changed to incorporate.
The early A & B versions of the 0 could not display the ladder.
For three axis machining, the 10 would most likely be the best choice.
But it would be handy to get a read out of the option parameters in either, the 0 are 900's and the 10 are the 9000's.
The 10 was the forerunner of the more sophisticated controls.
Al.
Albert E.
