Hi all
I am quite novice in many aspects in regards to cnc, so pls bear with me.
I have a router now running with simple nema23 steppers and mach3.
I use the router for very repetitive works, same pcs cut over and over again. I have the problems of steppers missing steps, most probably because of mechanical jamming of chips in the ballscew nut. After missing the steps the router keeps on working but obviously the position is wrong by 1-20cm.
I have also from time to time missed steps from software probably as it looses position (calculated at 0-0-0) of 0.2mm.
For the second problem I bought an Ethernet SS that is expected to arrive soon.
For the first problem I was looking into many solutions and consider several of them:
- replace the current steppers with hybrid steppers closed loop. It says they will make of for the missed steps, but there are also prblems as steppers will be forced to go faster to catchup
- servos - a bit expensive and hard to troubleshoot
- use simple encoders to current steppers that will just let mach3 (or SS) know stepps were missed and the router stopps.
I would be inclined to go for the last option. The work takes about 1.5hours, and i always cut in aluminium sheets that costs me each 50EUR. So i prefer to have the router stoped and start all over again.
Is ESS capable of receiving info from encoders and stop the router in case the error (missed stepps) is beyond the set limit?
How would I wire these?
CNC4PC
to the ESS if possible?
thanks
Marius
