586,655 active members*
3,359 visitors online*
    Apr 2003
    292
    Question BPort Series I and VFD questions
    I'm looking at buying an older series I bridgeport and I have a few questions. First off, I've noticed that the J-head machines tend to be considerably cheaper than the 2J heads.
    If I'm correct, you must manually change belt positions on the J head, and the 2J has the adjustable knob with a Hi and Low range, right?
    I don't have 3-phase available, so I will need a phase converter. I've heard that you can vary the speed of a 3-phase electric motor with a VFD, so I stumbled across the Mitsubishi S500. Does that look like it will work?
    I've heard of the ability to "overdrive" motors if using a VFD like the S500. As I understand it, if I run the VFD at 120 Hz, the motor will be spinning twice as fast as it was designed to, right?
    Can a Bridgeport motor handle this? Does this damage the motor or any other part of a milling machine?
    I'm thinking about getting a less-expensive J head bridgeport, then and using a VFD to do most of my speed changing, leaving the belts in one of the higher gears. I mostly cut aluminum, so I believe this should work, and if I have the ability to overdrive the spindle, that would be great! If I'm correct, the maximum (standard) spindle speed for J heads is 2720 RPM. 5000+ RPM would definately be nicer for aluminum!
    Feel free to correct me if I'm wrong, offer me advise, or point me in the direction of good, inexpensive milling machines and VFDs.
    My name is Electric Nachos. Sorry to impose, but I am the ocean.
    http://www.bryanpryor.com
    4826
    Hi NeoMoses
    Yes, you can run the frequency as high as you dare
    There are the usual mechanical hazards of running a motor at an rpm higher than it was balanced for, of course, and this includes the rest of the drive train on the mill head, too.
    Normally, there should not be too much trouble up to the 3600 rpm, since many motors are built for that speed. The quality of the motor's insulation has to be good, as frequency spikes can stress the insulation, and cause an eventual motor burnout.
    For single phase in, 3 phase out, you need to buy a Variable Frequency Drive that is approximately double the hp of what you would need if you had 3 phase input.
    I've retrofitted VFD's to various machines without problem. It is really nice to have the variable speed control available for your cnc to command.
    Have you checked Ebay for used mills? There are some real bargains there, if you have the means to do some retrofitting and repair.
    First you get good, then you get fast. Then grouchiness sets in.
    Apr 2003
    292
    what about this machine? I've never heard of a "Santec" milling machine, but it's got a BPort head.
    It looks to have about the same travel as a standard Series I knee mill, but has a much higher table load. Anyone have any experience with these?
    4826
    Do you want cnc?
    There are some good deals to be had buying used, complete with ballscrews, etc, even if you have to put a new control on it.
    To buy a manual machine and convert it, is likely not the cheapest route.
    There was a Wells-Index cnc mill on ebay with an old Bandit controller, maybe it will get re-listed. I have one of these machines, and it is a decent machine, with a good quality Z "quill box", and precision ballscrews all over (as far as I know). Some of the retros have quite a chicken sh!t connection from the quill to the Z ballscrew. You don't see this until you get it home, though.
  1. VFD for a single Phase motor!!
    By Yepez in forum Servo Motors / Drives
    Last Post: 08-11-2009, 12:53 AM
  2. Bridgeport Series II Retrofit
    By Cold Fusion in forum Vertical Mill, Lathe Project Log
    Last Post: 07-01-2007, 02:37 AM
  3. VFD installation with pics
    By Swede in forum Phase Converters
    Last Post: 12-07-2006, 12:21 AM
  4. Speed range for VFD and three phase motor
    By RotarySMP in forum CNC Machine Related Electronics
    Last Post: 04-20-2005, 08:05 PM
  5. VFD confusion, helllp!
    By Swede in forum CNC Machine Related Electronics
    Last Post: 06-15-2004, 12:05 AM
