WK1218 CNC router
This machine adopts imported linear square guide and 4 kines double slider. Large loading capacity, run stably,high precision,long life,accurate cutting. The whole machine use seamless steel, better rigidity,working table backing steel plate,rigid strength and loading capability of the machine can be more than one ton.Constant power spindle motor , powerful cutting intensity, high efficiency.Good compatibility for CAD/CAM software, including Type3, Artcam, Castmate,Artgrave etc.The cooling system for tools improves its life.
Specification:
X Y axis working area:1,200 x 1,800mm
Z axis working area:<300mm
Table size:1,450x2,020mm
Max. speed: 0-1,000mm/min
Max. working speed: 0-3,000mm/min
Working delicacy: 0.02mm
Reposition accuracy:0.05mm
Max. feeding height:300mm
Command: G code*.u00 *.mmg *.plt
Software: Type3,Artcam,Ucstudio software
Max. power consumption:6kW
Spindle: 4.5kWvariable speed,water cooled motor
Spindle speed: 24,000rpm
Work type:步进stepper
Working voltage: AC 380V,50/60Hz
Memory:32M
Manner of receiving data: USB OR PCI
Running circumstance temperature:0-45℃
Relative humidity:30%-75%
Weight:1,200kg
Application scope:
Granite, marble, bluestone, sandstone, glass etc stone engraving Density stone such as granite can be engraved to 3mm repeatedly Some stone such as marble, bluestone can be engraved to 3mm at one time.
