586,121 active members*
3,691 visitors online*
    Mar 2011
    Bridgeport Interact 1 MK 2 Heidenhain 151
    Machine was in mid pgm of drilling cycle when spindle slowed down and stopped. Switched m/c off and tried to restart spindle in pgm mode and no luck, so tried to start spindle in manual mode and still can't get spindle to rotate. Any help would be appreciated.
    Jun 2012
    516
    I bet you got f*cked by the MTI-1 board... look at diodes, caps, SCR's, transformers.
    Also, simply try to reset the overload (big breaker, also push button on klockner moeller OL).
    I've had loads of trouble with the MTI-1 board on my interact 1 mk2. the motor is fine, the FAC1R (and rest of the KTK drive) seem to be good.
    If the fuses blew on the MTI-1, its a good bet that something else is toast.
  1. Bridgeport Series 2 Interact 2 Heidenhain TNC 155
    By rrossey in forum Bridgeport / Hardinge Mills
    Last Post: 11-30-2023, 01:10 AM
  2. Bridgeport Interact 412/Heidenhain TNC 151 HELP?
    By larrynsr in forum Bridgeport / Hardinge Mills
    Last Post: 03-17-2012, 08:21 PM
  3. Bridgeport Interact 1 MK 2 Heidenhain 151
    By tommo61 in forum Bridgeport / Hardinge Mills
    Last Post: 11-30-2011, 11:35 PM
  4. Bridgeport Interact 1 - Heidenhain 2500
    By nycooh in forum CNC Machining Centers
    Last Post: 07-26-2009, 10:40 PM
  5. Bridgeport Interact 1 - Heidenhain 2500
    By nycooh in forum Uncategorised MetalWorking Machines
    Last Post: 06-25-2007, 09:59 AM
