586,701 active members*
2,548 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Okuma MC-4VA - Rigid Tapping?
    Oct 2011
    19
    I just bought a 1990 Okuma MC-4VA. Does it support rigid tapping?
    Feb 2007
    592
    Arrow
    Most likely not. - It was an option - but it was a very high priced extra.
    We bought new a 90/91 MC4-VAE-HS (30" X axis, 12000rpm spindle, 32 pot ATC) and at the time we thought the added cost for rigid tapping were way over the top.
    We used tapmatic heads modified to fit the spindle and allow use through the ATC. I now use Tension/compression holders that use the Bilz #1 type quick change holders and the built in G84 tapping fixed cycle. Works just fine.
    Oct 2011
    19
    Thanks for the reply. I will go with a tension/compression tap holder.
  1. Replies: 24
    Last Post: 05-01-2014, 07:02 AM
  2. g184 rigid tapping okuma lathe
    By pwanamaker in forum Okuma
    Last Post: 12-19-2012, 08:20 PM
  3. Replies: 9
    Last Post: 09-09-2011, 11:57 AM
  4. Replies: 13
    Last Post: 07-04-2009, 12:43 AM
  5. Rigid tapping or tapping head
    By kentavv in forum Charter Oak Automation Support Forum
    Last Post: 09-24-2006, 06:08 PM
