586,108 active members*
3,146 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Okuma MC4VA Wiring Question
    Oct 2011
    19
    The nameplate on my MC4VA says a max draw of 75 amps. I assume this is at the lowest voltage of 220V. I will be running the machine on 480V and am trying to dertrmine the size wire and breaker i will need. 75amps at 220V calculates to be 34.35 amps at 480V. Should I size my wire and breaker for the 34 amp draw that I calculated?
    Mar 2009
    1982
    I'll suggest simple. Check Okuma's main breaker terminals, what ferrule fits in. Then check the copper wire, the one what fits to the ferrule. This will be a step or two steps smaller, than Okuma recommends. Will work for years, sure.
  1. Okuma question
    By chrispare in forum Okuma
    Last Post: 11-08-2012, 09:47 PM
  2. okuma mc4va i need help
    By BakersMachine in forum RFQ Feedback
    Last Post: 02-16-2011, 12:18 AM
  3. Okuma LB25II OSP7000 Wiring Diagrams
    By chenzen666 in forum Okuma
    Last Post: 08-11-2009, 11:16 PM
  4. Okuma Wiring Diagram
    By pgcust in forum CNC Machine Related Electronics
    Last Post: 08-02-2007, 04:48 PM
  5. Wiring Question
    By The Wizard in forum CNC Machine Related Electronics
    Last Post: 01-04-2005, 07:11 PM
