I have installed a rotary Axis on my CNC and the gearbox has a 5/8 " keyed shaft. How would I go about attaching that to a wood lathe chuck?
Not enough info.
Dick Z
DZASTR
you can attach the gear box shaft with the chuck cylinder by means of pulley and v belt. chuck will be placed on the spindle and the draw tube is placed inside the draw tube cylinder.
you can try this
B Axis Rotation Is Stuck Up After B Axis Is De Clamped Hydraulically From Curvic Coupling. What Is The Probable Cause And Solution Of This Problem?
