586,217 active members*
3,282 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Flat Machined Dovetails (related to Gerry's thread)
Page 2 of 2 12
Results 21 to 30 of 30
  1. #21
    Apr 2009
    5516
    Quote Originally Posted by JerryBurks View Post
    I continued some design over the holidays (traveling and no access to the shop for some real useful stuff). It occurred to me that the "classic" dovetails are shaped to accommodate manual cutting and not really optimized for CNC machines. Therefore I simplified the shape so that it should be possible to machine this flat with an end mill and a small roundover bit. I think I will give this a try once I am done with a few other projects in the pipeline.
    You'll still have to flip the board over to round the other side of the "tails"... You might want to check out the Leigh Isoloc joints....
    As to "classic" dovetails, the problem with machining them on a CNC is handling the sharp corners. While there is a dovetail bit made that will round the tails on the flat, I think it's fine for kitchen cabinetry or commercial stuff, but I'm torn as to whether I would use it for a "craft" piece.
  2. #22
    Aug 2011
    999
    Quote Originally Posted by louieatienza View Post
    That is true, but should not be a big deal with a fence jig? Alternatively the pockets could be cut wider so that the tails fit without rounding on the other side and the resulting "defects" be hidden in a blind end.
    But for now that is only puzzle solving for me and no specific project.
    Edited to say: I just tried it without backside rounding on the CAD and it does not work. Well, it does work but would require milling the other side of the tails anyway so there is no real benefit.
  3. #23
    Apr 2009
    5516
    Quote Originally Posted by harryn View Post
    I like the blind joints. It is a great way to hide that you are using laminated pieces of ply instead of real wood.
    Only with a mitered joint... Unless the tails are on the plywood side.
  4. #24
    Aug 2011
    999
    I played a little more with the idea today and believe I found a geometry that works and is extremely simple without leaving voids in the joint. It can be cut with a single 30-degree v-bit (like the Amana In-Groove) and from one side only. I tried to calculate the required angle of the tenons but the vestiges of my trigonometry skills and spatial imagination left me stumped. But with a bit of trial and error I got it together without gaps. The key is that the parts don't join straight but with a 45-degree angle motion.
    The wood board needs to be clamped to the CNC at a 15-degree angle to cut the inside of the coves straight but that is easy enough with a pretty shallow wedge shape jig. While my machine does not allow clamping vertical parts, the spindle comes close enough the the edge (about 8 inch) to machine a slightly slanted board.
    I think I will try this out the next couple of days.
    http://www.youtube.com/watch?v=w-W5ygNEWkc
  5. #25
    Jan 2009
    141
    Re: Flat Machined Dovetails (related to Gerry's thread)
    I have been experimenting with Isoloc style joints a while ago (did not know the name though). They are pretty and functional but so far I did not come up with an idea to machine a 90-degree joint of that style with both parts flat. That is why I picked up on the more traditional style dovetails.
    But I made an experiment with an inline joint (or butt joint) of 3/4" plywood. After the glue set I whacked it with a mallet in a vise and it broke right next to the joint. The joint itself held up, seems to be a really strong connection.
    Jerry do you still have the file you used to make that "Isoloc" style joint? I want to use that to join boards together.
    Keith
  6. #26
    Aug 2011
    999
    Quote Originally Posted by keithstanley View Post
    Keith
    I will look. There was no special software involved. I designed the pattern in my CAD system and made the tool path in VcarvePro.
    Kind of unlikely that I kept that file because it was just for an experiment. But if I find it I will send you a PM.
    Box Joint and Dovetail CAM software here: WWW.TAILMAKER.NET
  7. #27
    Jan 2009
    141
    Jerry If you can find the file great.
    Is it possible to do that sort of thing using your software? You seem to have done it on one of the example boxes.
    Keith
  8. #28
    Aug 2011
    999
    Is it possible to do that sort of thing using your software? You seem to have done it on one of the example boxes. ...
    The finger joint software only does 90-degree joints (I do have a beta version that can do acute angles between 22.5 and 90 degrees but it does not work properly yet with larger bits). For the example box I made the lid and bottom puzzle cut with Vcarve and sanded the glued board flat before I started cutting the edge joints. One could develop software to automate the pattern generation for flat joints but I never looked into that because it is quite easy to draw that in CAD. But it might also be a nice Vcarve gadget.
  9. #29
    Jan 2008
    4
    I've been interested in this problem of machining 90 degree joints flat. I haven't found a good solution for dovetail yet, but I figured out a solution for finger joints. I created a design that allows one to CNC finger joints only mounting the stock flat, with no gaps. It does not require two sided machining. It also machines on the inside of the drawer, so you can cut a groove for a the bottom of a drawer at the same time. It uses a combination of straight, roundover and ballnose bits. I'm hoping it will be an efficient way to make a large batch of small drawers for myself. I'm still waiting for my CNC and I'm unable to go back to work and use the CNC there, so for now all I have is the Fusion 360 simulation.
    It's a parametric design in Fusion 360 so you can adjust the dimensions, board thickness, number of fingers and it will recalculate automatically. Unfortunately the CAM will not necessarily recalculate, but the design should have all the right contours for the CAM operations.
    Short explanation video
    https://youtu.be/2piJe4UAKWo
    Design file
    https://a360.co/3g4L27B
  10. #30
    Jan 2008
    4
    Correct design file is https://a360.co/2CPozx8
Page 2 of 2 12
  1. LouieAtienza's "Dovetails on the Flat" Technique, take 1
    By louieatienza in forum WoodWorking Topics
    Last Post: 07-27-2020, 08:16 PM
  2. Replies: 0
    Last Post: 08-26-2013, 05:41 PM
  3. Reference Flat for Scraping Dovetails
    By Ed from NY in forum Uncategorised MetalWorking Machines
    Last Post: 08-21-2009, 05:47 AM
  4. screw thread mounting without machined ends
    By Action-KAT in forum Linear and Rotary Motion
    Last Post: 08-19-2008, 11:57 PM
  5. Help with a flat thread
    By shawn in forum G-Code Programing
    Last Post: 07-15-2005, 06:24 PM
