Model Number: FC- 0212AY-8 or 10
Patent Number: 201110266081.6/ 201120337010.6
Lathe Bed: Steel structure, seamless welding
Component of Lathe Structure:Casting Aluminum
Outer Side: 3100*2200*2400 mm
Working area: 250 x 1200mm x 8 rotaries/ 9 rotaries
X, Y, Z Transmission: Taiwan TBI Ball Screw
Rail: Taiwan Square Rail 25 mm
Spindle Motor: 2.2KW*8 Constant power water cooling spindles
Spindle Rotating Speed: 6000-24000rmp/min
Control System: Origin NCstudio 4th control system
Typeset Software : UCANCAM V9, ARTCAM
Reposition Accuracy: 0.025 mm
Motor : Japan Yaskawa Servo
Driver : Japan Yaskawa
Frequency Changer: 4.5KW*4
Work-holding: Pneumatic clamping
Working Voltage: AC220v/50HZ
Advantage: 1.Four-axis linkage processing center, in addition to the three coordinates of linear motion outside, and one rotating coordinates of the movement for process cylinder material in vertical.
2. VSR (Vibratory Stress Relif) for extend the lifetime and keep high accuracy of lathe.
3. Pneumatic clamping for clamp and remove easily.
4. 8 to 10 sets of spindle for process in batch.
5. Rotary Fourth axis for deep 3D engrave.
Ms. Zoe Zhang
Beijing Fanch Machinery Co., Ltd.
Mobil: +86 18701304527
Tel: +86 10 60277800
Email: [email protected]
Website: ??????????
