586,082 active members*
3,837 visitors online*
IndustryArena Forum > MetalWorking Machines > Deckel, Maho, Aciera, Abene Mills > DMU70 Siemens 840D 5ax feedrate question
    Mar 2006
    69
    In 5ax mode with TRAORI and Cycle832 active My feedrate of 90IPM does fine in a straight X/Y/Z move but then slows to a crawl when a B or C move is called out. (Utilizing a bunch of tiny G1/Vector moves)
    The Hypermill Tech seemed to think it was the job of the controller to advance the B/C Feeds to keep the same SFM of part going past the tool. The machine tool tech feels that the holdup is the C axis rotating at 90IPM (as measured at the outside dia of the table)
    How do I keep a consistent feedrate at the tooltip?
    Thank you,
    Brian
    Mar 2006
    69
    For those that might also be struggling with this. It was suggested by my Hypermill tech guy to change the Cycle832 setting from finish to pre-finish or roughing. Worked great - I think I actually got a better finish on my pre-finish part. Part times were 33,12,8 mins respective - same program just changed the mode.
  1. SIEMENS 840D PROGRAMMING QUESTION
    By toro in forum G-Code Programing
    Last Post: 05-14-2016, 04:30 AM
  2. Need Siemens 840D Help
    By gears2010 in forum SIEMENS -> Sinumerik 802D/808D/810D/828D/840D
    Last Post: 07-25-2013, 03:54 PM
  3. SIEMENS 840D
    By BKCOM in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 12-08-2010, 11:21 PM
  4. Looking for some Siemens 840D work?
    By Irvingw in forum SIEMENS -> Sinumerik 802D/808D/810D/828D/840D
    Last Post: 02-11-2010, 08:31 PM
  5. VB & Siemens 840D
    By Thunder in forum Visual Basic
    Last Post: 09-22-2007, 04:28 PM
