Hallo,
i have a Prolox 60 with an Ercocut s45 on my DIY PLasma cutter. In this moment i use only the Z Switch in LinuxCNC but i will build a THC with an small microcontroller.
So i need a voltage divider, or is there a port with a 5V (or industrie 10V) analog signal ? Can i build the divider with (4,7k+4,7k) + 220R resistors with 5W and LC Filter? can i but it direct on the + and - cable, or is there a better measure point ?
Welbach PROLOX60 Welbach PROLOX60 2046
greatings Malte
