586,096 active members*
3,412 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > How much shank in an ER32 collet?
Results 1 to 7 of 7
    Oct 2012
    61
    I am loading a 21/32 inch drill into an ER32 collet, and the only drill I have available had most of the shank ground down to a half inch. I don't have any half inch collets available, so I'm trying to clamp onto what's left of the shank. I have about a .625" length of full diameter shank left. Is 5/8" long enough to hold a 21/32" drill reliably? I am using it in a lathe on 1018 steel, drilling about 3" deep.
    May 2004
    4519
    Yes.
    Oct 2012
    61
    Thanks. Saves me a headache. Seems like no matter how many half inch collets we buy, there are never enough.
    I wouldn't recommend doing this regularly.
    Most ER collet manufacturers will typically recommend clamping a shank that is at least 2/3rds of the collet length. In the case of an ER32, the total length is 1.58", so clamping only 0.625" = 40%. If you overtighten the collet nut, the collet could split.
    You may be able to do this occasionally to get you out of a bind, but it really isn't ideal and will eventually cause damage to the collets.
    -Sol
    http://www.orangevise.com
    Jul 2005
    12177
    Drills do not experience a side load so you can get away with gripping a length less than one diameter. On milling cutters it is better to grip a length equal to 1-1/2 to 2 diameters.
    Apr 2002
    5003
    It were better if you take a small disc with 1/10" height to the end of the collet. The disc must not be bigger than your drillshank, a little bit (2 thou) smaller isn't bad.
    May 2005
    3920
    You might as well buy a new collet and drill bit!
    While you may get away with it you will ruin the collet eventually. You also run the risk of spinning in the collet. As for the drill bit did you slap the guy that turned the shaft down? I only ask because normally when you see such in a shop, said drill bit will suffer from excessive run out.
  1. ER32 Collet Nut
    By Starleper1 in forum Benchtop Machines
    Last Post: 08-31-2009, 11:26 AM
