Originally Posted by
fomaz
Hello. I have a question about a machine with a 21i-T. I had a 21-T that did what I want and I explain:
When running a program, both rapid feedrate or cutting feedrate could be overided by the same rotary button (with several positions). In fact also the jog feedrate could be set by the same button. This was perfect.
On this new machine, I have a button for overide the jog and a button that can only be set in three positions for the rapids: 0% 50% and 100%. 50% rapids will be 12m/min that are way to fast, and I would also do not want to lower the max rapid feedrate.
I would like to use only one button, that would be the feedrate button. I have no trouble in changing the ladder, but I ask for a recommendation as it could be a better way.
Thank you
