CNC Help! Milltronics Partner III- Encoder Issues
Hey all,
Hoping you can all help us at the shop.
We purchased our first CNC machine to make simple 2D parts ( through holes, counter bores, pocketing, exc ) a couple months ago and things seemed to be going great. We have our own separate programmer ( who is quite rusty; using M4 instead of M3, a lot of air time when it should be rapid, and breaking bit after bit after bit.. frustrating to say the least )
But now we are experiencing a lot of problems over the past 2 weeks. Every morning when we start up the machine ( if we are working on the same project (60 or so parts )) we have to re-zero the part because the Y axis is always off .040” to .060”. and sometimes when we load a program, it automatically shuts down with a black screen saying shut down the machine and boot up ( which doesn’t seem like an encoder issue?)
The past two days have been very bad. In between tool changes, even at 100% feed, the XYZ axis’s would crawl almost like it was at 10% feed. This does not happen every time; usually “works” if we restart the machine, which is ludicrous.
So it has been a mixture of incorrect programming, and (possibly) encoder issues
The X axis always seems to be spot on
Our main concern is the z axis right now, because re-zeroing X and Y every time the machine is started up is not a huge problem.
So yesterday we started to LIGHTLY disassemble the machine ( just the top cover that exposes the belts ) and two side small panels that also exposes the Z motor and some wiring
What is the easiest solution here? We called Milltronics and the service person said to inspect the coupling in-between the motor and the encoder, but I personally cannot locate what the encoder is
I took a handful of pictures to make this easier for both of us :-P
1 http://i47.tinypic.com/33tqx6f.jpg
2 http://i48.tinypic.com/11mdts3.jpg
3 http://i46.tinypic.com/o0a3kn.jpg
4 http://i46.tinypic.com/nfnnfo.jpg
5 http://i48.tinypic.com/67mb6b.jpg
